![]() Drives: 2016 Camaro 2ss Red Hot Join Date: Jan 2016
Traction issue?
2016 stock Camaro ss. Can this car just not put the power down ever without spinning the tires? I know it's rwd but isn't too much power. This is my first higher horsepower rwd car. Is this normal to expect?
![]() Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Can't speak to the Camaro yet as only have taken a few test drives before factory ordering. I do have experience with BMW rear drive with less HP than the Camaro and you had to feather the throttle or your were either kicking in traction control (eating up rear brakes) or eating up rear tires.
Yep I'm back!
Drives: 2017 Krypton Green 1SS 1LE Join Date: Mar 2009
My camaro has never spun the tires once and I'm over 1100 miles sounds like you got a heavy foot.
![]() Drives: 2106 SS Join Date: Aug 2016
If you have traction control on I very realrly spin my tires
Sent from my SM-G935V using Tapatalk |
#5 | |
![]() Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
#7 |
Yep I'm back!
Both of you guys missed my point, tires don't just spin your foot makes them spin. So Kevin like I said sounds like you have a heavy foot, take it easy on the gas pedal and the tires will stop spinning unless you want them to.
#8 | |
Yep I'm back!
#9 |
Lol. Your point is irrelevant. I'm obviously talking about full acceleration tire spinning and if there is a better tire to prevent this more.
#10 |
Yep I'm back!
#11 |
#12 |
Yep I'm back!
You should of said I have the following tires on my car, insert type here, and I am having problems with wheel spin under full throttle acceleration. Only thing in your original post you mentioned was car has a lot of Hp and can't keep from spinning wheels. We're suppose to infer from that you want tire reccomendations?
#13 | |
#14 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Drag radial.
