Old 04-16-2017, 10:29 AM   #1
subchev
subchev's Avatar
Drives: dealership
*If You TOW - You Must Read This*
Work hard. Play hard. That's the old adage, isn't it?
We all worked really hard to get our Camaros.
and when you finally got your Camaro. Well...
That was probably one of the best days of your life and you did not look back.
The best thing is, you probably have not lost your work ethic.
It might be all speed and shine when it comes to the Camaro
but the person behind the wheel is the same hard worker
who put it all together and got the car of their dreams.
Not very many people use their Camaro to tow, but that's what we are here to talk about:
BUT You probably have a workhorse vehicle that does everything that your Camaro should not be doing.
...or maybe it should
One of those things is towing cargo trailer, motorhome, etc.
There are tons of vehicles that can tow, but there are not a lot of hitches that do anything other than just towing.
But, if you are going to work hard and play hard then wouldn't you want to play hard for longer periods of time? You can do that if you get the right hitch that does more for you than just tow.
"What else can a hitch do?"
It can weigh the cargo for you. The tongue weight, at least.
Pressure on the ball sends a reading to the built-in scale that measures tongue weight (lbs.) GMC guidelines for proper towing states tongue weight should be no less than 10 percent of gross trailer weight (GTW) and no more than 15 percent. For example, tongue weight for a 10,000 pound trailer should be no less than 1000lbs. and no more than 1500lbs.
The Importance of Tongue Weight
The Weigh Safe Drop Hitch effectively measures the tongue weight of your towing load, ensuring that your vehicle is balanced properly and is safe to tow.
Injuries, fatalities, and loss of property are all preventable by ensuring proper tongue weight.
You just load your equipment and let the scale do the work for you. You know exactly how much you have in your trailer and if it will be too much weight. It is literally that easy. Just load your cargo and look at the built-in scale.
You know what else would be great? Getting this fancy hitch at 10% off. You can get the hitch and the deal here. http://www.trunkmonkeyparts.com/weighsafe
Simply select which one will be right for your vehicle. You can even get the new 180-degree hitches that feature two different ball sizes instead of the single ball size.
If you tow anything at any time then save time and make it easy for yourself. Use the promo code: WEIGHSAFE10 and spend more time playing than working hard.
Also, there are other accessories such as extra balls, a dust cover, and a locking hitch pin and we will even make sure the keys match so you don't have two different sets of keys for one product.
More info available here!!
subchev is offline   Reply With Quote
Old 04-16-2017, 12:03 PM   #2
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
What is the tow capacity of the Gen 6? I'm debating getting a class 1 hitch and Autocross trailer for wheels
Eric SS is offline   Reply With Quote
Old 04-16-2017, 01:42 PM   #3
Odd Jobb
Odd Jobb's Avatar
Drives: 2016 Camaro SS1
The torque rating on my Camaro is higher than on my full size Truck!! Should be able to tow a bridge,,,lol
Odd Jobb is offline   Reply With Quote
Old 06-07-2017, 11:01 AM   #4
subchev
subchev's Avatar
Drives: dealership
Bolt-On Hitch Package
General Motors now offers a bolt-on hitch package for the Gen 6 Camaro!
CAMARO 6 ACCESSORY HITCH PKG CARRIER MOUNT - GM (19354462)
Custom fit, vehicle-specific accessory hitch with a 1-1/4" receiver tube opening that accepts THULE bike racks with a 110 lbs maximum capacity.
The WeighSafe hitch is not compatible with the smaller receiver,
the hitch is designed for carrier mounts only with 110 lbs max.
Here are the Carrier Mount options from General Motors:
HITCH-MOUNTED BICYCLE CARRIER - VERTEX™ 2 BIKE HITCH RACK W/ LOCK BY THULE® - GM (19331866)
Hitch-Mounted Bicycle Carrier. Transport up to two bikes with a Hitch-Mounted Bicycle Carrier. Conveniently fits into your vehicle\'s trailer hitch. Carrier tilts away from vehicle for access to rear cargo area. Non-GM warranty. Warranty by Thule. Pictured below.
BIKE FRAME ADAPTER BY THULE® - GM (19353376)
Bike Frame Adapter by Thule. Installs on women\'s, BMX and non-standard bicycle frames to permit use with hanging-style hitch mount bicycle racks. Associated Accessories, non-GM warranty. Warranty by Thule. Pictured below.
HELIUM AERO 2-BIKE CARRIER WITH LOCK BY THULE® - GM (19366638)
Hitting the bike paths and trails is easier and less taxing, thanks to the Helium Aero 2-Bike Carrier with Lock by Thule®. It’s nearly half the weight of most hitch racks and is the ONLY ultralight rack to integrate maximum convenience, bike protection and security into one sleek aerodynamic design. It features patented Hold Fast Cradles with Road Dampening Technology to secure the bike to the rack while absorbing road shock. An integrated locking cable and AutoAttach lock knob lock the bike to the carrier and the carrier to the vehicle. Carrier tilts away from vehicle for access to rear cargo area. Non-GM Warranty. Thule® provides a 3-year/36,000-mile manufacturer’s warranty. Pictured below.
Old 06-07-2017, 12:28 PM   #5
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Camaro has a towing capacity of ZERO pounds. Vehicle is not intended nor designed to tow any trailer. That GM bike rack hitch is it.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 06-07-2017, 12:39 PM   #6
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I've been towing our 31' Prowler camper with our Camaro for a year now. No issues at all. Lol
Old 06-07-2017, 02:18 PM   #7
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
[SIZE="3"]Custom fit, vehicle-specific accessory hitch with a 1-1/4" receiver tube opening that accepts THULE bike racks with a 110 lbs maximum capacity.
Here's what it looks like installed...
...and here's how it looks in action. I use a Thule 2-bike platform carrier. Less bounce and sway than a hanging carrier. I had a Thule 4-bike hanging carrier that I used with other vehicles until I got the Camaro.
Ironically, I had just come in the house from a long bike ride when I saw this thread.
Last edited by Martinjlm; 03-01-2018 at 06:40 AM. Reason: Replacing images lost due to Photobucket
Old 06-07-2017, 02:22 PM   #8
Martinjlm
Martinjlm's Avatar
One of the guys on the Camaro team has a poster in his cube that reads "The only thing a Camaro needs to haul is ass"
Old 06-07-2017, 04:26 PM   #9
fastball
Drives: 2017 Camaro 2SS 6MT
People forget, towing is about a lot more than engine or even transmission capability. Suspension and the entire chsssis all contribute to a vehicle's ability to tow something.
No Camaro ever built was ever intended to tow anything or carry more than about a thousand pounds inside the car. That's it.
fastball is offline   Reply With Quote
Old 06-07-2017, 04:53 PM   #10
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I had this hitch on my 5th Gen. In the instructions, Thule said that you had to run a strap back to the car from the top or it would void their warranty. I figured I couldn't use this on my 6th because there is no place to attach the strap too that won't rub paint. Is that still the case?
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 06-07-2017, 05:13 PM   #11
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Pic! What hitch???
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 06-07-2017, 07:20 PM   #12
redcoats1976
wots next,some chrome nekkid lady mudflaps an a bloomin stack?
redcoats1976 is offline   Reply With Quote
Old 06-08-2017, 11:54 AM   #13
iPODFAN11
iPODFAN11's Avatar
The 5th gen V6 and SS cars were rated to no more than 1,000lbs towing and no I am not joking.
Old 06-08-2017, 06:42 PM   #14
Donner
Drives: 2017 50th SS convertible
+1
Donner is offline   Reply With Quote
