Springs for a Vert w/MRC
Anyone producing lowering springs for MRC convertibles yet?
![]() Drives: 2018 ZL1 Garnet Metallic A10 Join Date: Feb 2016
^^+1^^
Buck
"I don't anymore, but I ustacould!" 2018 ZL1 Garnet Metallic |
![]() Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT Join Date: Sep 2016
AFAIK, the Eibachs and BMR are compatible with MRC, and there are no restrictions on the vert vs. coupe, unless I missed something. . . .
Are they making a convertible spring?
![]() Drives: Camaro - All Black Convertible Join Date: Jan 2015
I don't have MRC on my vert, but after checking with Eibachs and BMR, they didn't state support for a Vert. I looked at Hurst, and they do state support for a vert.
From Hurst Website: The Hurst Stage One Spring Kit for the 2016-2017 Camaro SS (Coupe and Convertible) is an excellent choice for firming up the handling of your car and giving it that "just right" stance. I chose the Hurst kit. |
Seems like the convertible would be heavier in the back, and require a slight stiffer rear spring.
#7 |
Yeah, I guess I didn't consider the weight disparity. . . I'm kinda getting used to my stock springs, the wheel-gap initially really bugged me. . .
#8 |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
Eibach and BMR. Check out my build, I just installed Eibach.
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build Last edited by ChadFarr; 05-23-2017 at 04:15 PM. |
#9 |
SO I love my drop on my eibach springs but the bolts that hold the braces continuously bottom out or scrap when going over speed bumps. I'm probably going to re-install my stock springs on the rear.
Click & Follow My Build |
#10 |
I lowered my Vert with Hurst springs. They were the only company that specifies convertibles in their documentation.
#11 |
Do you have a picture? The factory wheel gap on the rear isn't that bad anyway bc I want to put a meaty tire on.
#12 |
Sorry to hear. That's the original reason for asking the question. If the convertible is heavier in the back, it will require a different (firmer) spring rate.
#13 |
Eibach now offers another set of SportLine springs designed for the 1LE which is a .7" drop instead of their standard 1.1" drop. I'm waiting to see what they'll be able to offer me. If not, i'll either get rid of eibach for hurst or just put my stock springs on in the rear.
#14 |
![]() Drives: 16 2SS Convertable Join Date: Feb 2018
Just installed the Eibach E10-23-018-01-22 Camaro SS pro-kit, looks awesome! It says to drive it hard for 10 miles after the install to seat everything, so I did around 30. They claim vert compatibility, and the Kits paper work called it a ZL1 upgrade. No bumps, scrapes, noises. The ride is tight when pushed, smooth on easy driving.
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
