Old 04-13-2017, 02:43 AM   #1
HB1SS
Drives: 17 1SS
Fun Times....
So I was cleaning the SS and with the drivers door open and it locked- maybe I hit the lock button when I was cleaning the door panel. It then would not close as the latch would not clear the striker. I tried to use the fob and the door panel button to unlock- not working. I saw in the manual that you could pop off the handle end and use the small key in the fob to open the lock manually -still did not work.
I got a bungee for the door and set out for the dealer.
Now it seems the car thinks someone is trying to steal it and it will not start.
Battery is fine.
No help from OnStar.
Roadside Assistance could not get it started.
AAA could not get it started.
Car is backed into my garage and I don't want it dragged/winched out.
its only one month old!!!
Any Ideas?
HB1SS is offline   Reply With Quote
Old 04-13-2017, 03:08 AM   #2
AndyUK
Drives: 2017 Camaro SS
Try disconnecting the battery for 30 minutes and try again, or talk to your dealer maybe?
AndyUK is offline   Reply With Quote
Old 04-13-2017, 05:13 AM   #3
one R
Drives: 2017 1ss
when my windows got tinted i saw the tint guy moving the stricker assembly in and out to get the window to go up n down through the index of the window ... Is your window fully up or is it in the slightly lowered position .. you may need to manualy put something in there to force the striker plates into the open position
one R is offline   Reply With Quote
Old 04-13-2017, 10:38 AM   #4
HB1SS
Drives: 17 1SS
Window does not "notch" down to close but will go fully up and down with button. The problem is the latch mechanism. Tryed a screwdriver to pry it but no luck.
No luck on disconnecting the battery either.
Old 04-13-2017, 07:58 PM   #5
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Try making the computer think the door is closed properly by depressing the switch that tells it the door is closed.
Then hit the fob unlock button. Just a guess.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 04-13-2017, 08:32 PM   #6
SuperDave70
Drives: 2LT Fifty
I think this guy might be a genius!
SuperDave70 is offline   Reply With Quote
Old 04-13-2017, 08:44 PM   #7
foundcamarolifeisgood
Drives: 2011 2SS
sounds brilliant...hope it works
foundcamarolifeisgood is offline   Reply With Quote
Old 04-14-2017, 08:53 AM   #8
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
The striker catch might be 'partially' closed - like you closed the door but it didnt close all the way. Try pushing the catch all the way in, the pulling it back out while opening the door from the inside.
mekirk2 is offline   Reply With Quote
Old 04-14-2017, 08:56 AM   #9
1hevy_chevy
1hevy_chevy's Avatar
Drives: Nightfall Gray 2016 6M 2SS
+1 for disconnect battery for 30 mins.
Rotofab CAI, Mishimoto Catch Can. Other than that Stocky-McGee for now
1hevy_chevy is offline   Reply With Quote
Old 04-14-2017, 08:58 AM   #10
mekirk2
mekirk2's Avatar
There is not a switch (at least there is not one on the verts). Many of todays cars have the switch built into the latch mechanism.
Old 04-14-2017, 09:00 AM   #11
mekirk2
mekirk2's Avatar
BTW - are you sure the door is locked? Is the passenger door locked as well? If the passenger door is unlocked, chances are the driver is as well and its an issue with the position of the latch itself that I mentioned above.
Old 04-14-2017, 02:11 PM   #12
HB1SS
Drives: 17 1SS
Finally got it to unlatch yesterday. Needed to jimmy plastic latch while holding door handle open
Now car starts and it fine.
This whole thing was bizarre .
Thanks for all suggestions
Old 04-14-2017, 03:06 PM   #13
Drives: 2011 2SS
Congrats!
Old 04-14-2017, 06:40 PM   #14
DenverTaco07
DenverTaco07's Avatar
Very bizarre and frustrating i'm sure, glad you got it.
