Old 04-12-2017, 04:54 PM   #1
SSnakeEater
Dyno results :(
I wish I would have done a baseline when my car was stock but oh well. Anyway, I took my car to get dyno'd today to see where I stand with all my mods and I am a little disappointed at the results. 452HP/459ftlb.
Dyno was a Superflow and current mods are: Kooks LT 1 7/8 catless headers, MBRP race exhaust, EFI tuning e85 conversion kit w/tune, Roto Fab CAI and ported throttle body.
Pull was done in 5th gear because the guy said 6th gear was too long of a pull. He also said that Superflow falls in the middle of Mustang and Dynojet.
SSnakeEater is offline   Reply With Quote
Old 04-12-2017, 04:58 PM   #2
slick3
Drives: Garnet Red - 20 ZLE
Those are good numbers.... you shouldnt be dissapointed with those.... who did your tuning? Did you take logs? Send the logs to your tuner and see if he can make some small tweaks for you.
slick3 is offline   Reply With Quote
Old 04-12-2017, 05:05 PM   #3
SSnakeEater
Tim did the tuning and I do have the logs.
Old 04-12-2017, 05:18 PM   #4
slick3
Send them and see what he says....
Old 04-12-2017, 05:18 PM   #5
313inthed
313inthed's Avatar
Drives: 2016 2ss vert
452hp with E85?
2ss vert sliver ice| adrenaline red| knee pads| black rally stripes| 6-speed| npp| black bowtie|
illuminated footwells| splash guards
ordered 3-28-16
tpw 5-2-16
vin 5-6-16
4300 5-17-16
5000 5-19-16 Delivered!!!
313inthed is offline   Reply With Quote
Old 04-12-2017, 05:20 PM   #6
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
At worst, you could ask the local guys with 6th gens if anyone would be willing to run their stock cars on that dyno to at least get something approaching a solid baseline to compare against.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 04-12-2017, 05:20 PM   #7
SSnakeEater
Yeah. I thought it was low with the mods I have.
Old 04-12-2017, 05:40 PM   #8
vince3
Drives: 2022 Vivid Orange LT1-M6
Go get it dynoed on a dynojet if you want to compare with others.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 04-12-2017, 05:42 PM   #9
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
If it's a manual I think it would be lower than an auto. Mine baselined lower than an auto(380s compared to 400s. I don't think this a8 loses as much through the drivetrain. Maybe I'm wrong tho.
Mine was about 380ish stock, 360-ish with Cai cai, pray ported TB, pray ported IM , kooks 1-7/8 catless, 3" axleback with 4"round straight through magnaflow. (It ran shitty with that and no tune. With tune it put 425hp, 432-ft lbs to the wheels. (Winter blend fuel)
Just my .02
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 04-12-2017, 06:32 PM   #10
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
I've reviewed the log data and everything looks great. The lambda values are very close to where they should be. Timing is where it should be. The MAF readings were down compared to my car's last dyno (similar setup and identical MAF transfer function). That is simply weather and/or elevation.
It just is not valid to compare results from different types of dynos. Dynos really should be utilized to validate deltas (ie. same car, same dyno).
Tim
EFI Tuning is offline   Reply With Quote
Old 04-12-2017, 06:36 PM   #11
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Is this a manual? If so it was pulled in 5th?? I thought the 1 for 1 was 4th?
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 04-12-2017, 07:07 PM   #12
PRAY
PRAY's Avatar
Drives: 2016 2SS
If this is an A8 car and it was pulled in 5th then those are great numbers. 5th is down 20/30rw to 6th in my car. You don't have a ported IM? Who's TB is it? What was the E content?
Old 04-12-2017, 07:15 PM   #13
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Dynos are tuning tools. If you don't have a baseline why are you disappointed? You have literally no idea what you gained.
If all you care about is telling people how much WHP your car makes, yeah I'd be disappointed with 452. But let the car do the talking. My car makes 420 on a low reading dyno, I love telling people that then gapping their car that makes 460 on a dynojet.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 04-12-2017, 07:18 PM   #14
PRAY
PRAY's Avatar
Drives: 2016 2SS
The two DJ's I use are consistently 30rw apart. On the one dyno on pump gas in 5th the most my car has ever put down was 410/425rw. I don't dyno in 5th on the other so I am not really sure what it would say. But I have gone 11.2's@122 on pump gas at 3,840. Anyone think those numbers add up?
