Old 04-11-2017, 10:35 AM   #1
whollins
Drives: Camaro
Service Side Detection System Message
I did a quick search and couldn't find anything on the forum. Started the car today and received an error massage that says "Service Side Detection System".
1400 miles on a new ZL1. UGH
Anyone else seen this?
whollins is offline   Reply With Quote
Old 04-11-2017, 10:45 AM   #2
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
Fault in the blind spot monitoring system? Is it still functional?
ScottMZ3 is offline   Reply With Quote
Old 04-11-2017, 01:26 PM   #3
whollins
Drives: Camaro
No. The blind spot detection system is not working on either side of the car.
Old 04-11-2017, 05:16 PM   #4
ScottMZ3
ScottMZ3's Avatar
Time for a trip to your friendly neighborhood Chevy service department! :(
Probably a very simple fix though!
Old 04-20-2017, 04:40 PM   #5
whollins
Drives: Camaro
Update
Took it to the dealership today. They just had to do a reset on the system.
Seems to be working fine now. Glad it was a simple fix.
Old 04-20-2017, 05:00 PM   #6
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Interesting. Is that like a battery unplug then replug, or something more entailed?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 04-20-2017, 05:19 PM   #7
MostlyHarmless
Drives: 2016 2SS A8 Convertible
Mine generally works fine but I have noticed it is mega sensitive in heavy rain. Getting a lot of false alerts on the driver side. As soon as the weather clears up it goes back to normal.
Not sure if there is any sensitivity adjustment that the dealer can do on the sensor. And honestly not sure I care enough about it to risk having the dealership mess around with my car. Generally I use my truck if I know it will rain so I don't rely on the sensors in bad weather too often
Mark
MostlyHarmless is offline   Reply With Quote
Old 04-22-2017, 06:54 PM   #8
whollins
Drives: Camaro
I assume they unplugged the battery because I lost all of my settings in my HUD and seat settings.
Old 10-25-2017, 06:21 PM   #9
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
Resolution for Side Detection System after Jumpstart
This happened to me today when I had to jumpstart my car after sitting for a week or so. To resolve his issue all you have to do is turn the car off and turn it back on again and driving around for 5 min or so. It fixed the problem for me.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 10-26-2017, 12:41 AM   #10
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Was it raining or anything? AZ, prob not, but just wondering
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 02-13-2018, 01:18 PM   #11
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
mine started doing this after a drive home yesterday in some light AZ rain. Ican turn on and off the system but is doesnt respond the passing cars. Its bone dry today. So disconnecting the battery will fix? I have a oil change coming up. Will have them look into this
BIGTIME is offline   Reply With Quote
Old 02-13-2018, 01:29 PM   #12
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
This along with ‘service stability track” issues can be from a low battery and the software setting up a glitch. Make sure the battery is above 12.2V, disconnect the negative cable for 15 minutes, and reinstall. The car should reset.
Old 02-13-2018, 02:52 PM   #13
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
Thanks Glen! I will try to disconnect the battery or wait until my next service . Thanks again for the reply
Old 04-22-2021, 03:48 PM   #14
Andrew S
Andrew S's Avatar
Drives: Camaro 2SS Redline Edition
Sadly I have the same message and its not as simple as reseting it :(
It started going haywire in the wet spring weather, and now stopped working altogether.
Can someone give me a link to the sensing unit in the rear bumper that I amy need to replace? Although I am hoping I just need to dry it out, replug and seal it.
Just want to know what the unit is before I take of the bumper.
Andrew S is offline   Reply With Quote
