![]() Drives: 2017 Camaro SS M6 Join Date: Apr 2017
Catted Headers and Exhaust
Hey guys, I'm new to the forums and not necessarily a guru when it comes to cars. Basically, I live in California so I need to have cats on my car, but I'm planning on eventually getting a cam for the car after the bolt ons are in. I was wondering what's a good headers/exhaust set up to run for a mild cammed car and what high flow cats would be recommended. Thanks!
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Congratulations on your car and first post. Welcome to the forum you have alot to read! Since you mentioned you are not a guru I would suggest to read all the threads pertaining to exhaust options. You will find some good information on other parts in those threads usually too. The exhaust you want is going to depend on your preferences. There is plenty to choose from with very similar gains.
If you are not going forced induction stay with 1 7/8" vs 2" primaries and long tube headers. |
Agree with getting a set of catted long tube headers, 1 7/8" x 3" for naturally aspirated or 2" x 3" if you eventually plan to go with a blower or other FI. If you went 2" off the bat, you may lose from low end torque, but that's what you'd want at a minimum if you knew you were going to get a blower. ARH and Kooks are supposed to be the top of the line IMO for headers.
You can leave the stock exhaust or go aftermarket, Borla is the option I went with for the sound quality and no drone characteristics, it depends on what you are looking for. You can certainly read the threads here about which systems have drone, but when it comes down to which one you will prefer the most, go to car meets, find a guy on the forum local to you, hit up a cars and coffee and go hear it in person (both inside and outside of the car) if you want the most accurate info on what you will like because the stuff isn't cheap! |
#4 | |
I see. I plan on not going FI yet, or ever for that matter as it is a daily. I was just looking for probably a set of catted KOOKS Headers since I've heard nothing but good things about those. What size headers should I get if I keep the stock NPP exhaust then? Thanks. |
#5 | |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Let me help you out a little.... LTH in california are illegal anyway you cut it. End of story.
You could put "cats" on any LTH and it will still be, yes...illegal. If you change the position of the CC, you no longer are abiding by CARB laws. With that said, Put headers on the car, get cats for them, dont put a stupid loud axle back on the car or better yet keep the stock one. You get all the gains without the attention. If you car sounds stock CHP and the police are less likely to crawl under your car and start cracking the whip on you. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
no reason not to go fi because its a DD. superchargers have bypasses now. drivability is stock until you put your foot in it.
#8 |
I just recently put Stainless Works LTH with high flow cats on my car. I'm not a fan of Kooks at all, they don't put the numbers up that SW and ARH will do (kooks are cheaper for a reason). I went SW all the way back to my factory NPP and it sounds great. Caution, if you go 2" you will have fitment issues on the driver side with the steering linkage. SW sounds great and is a solid product. Welcome to the forum and good luck with your build! There are tons of topics to read over on here.
P.S. I'm going pro charger on my daily.. these days, the car keeps its drivablity. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
kooks have actually been showing the highest dyno numbers so far that ive seen on this forum.
#10 |
I'm not doubting you, but I'm yet to see it man. They don't sound as good, and they aren't true equal length. All the data I can find on SW, they put a higher number up. I got 71hp out of my set up with a FI cam
#11 |
![]() Drives: 2016 Camaro 1SS Red Hot Join Date: May 2016
Stainless Works are actually one of the cheapest I've seen.
#12 |
The exact opposite for me. The Kooks I had in my hands were not that great and they are cheaper by a few hundred bucks. The ARH I've never personally seen. My SW look to be the same quality as my hooker and Gibson headers from days past.
#13 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Completely subjective opinion regarding the Kooks. Factual information does not agree with your views against Kooks.
#14 | |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
