Old 04-10-2017, 11:13 AM   #1
rdoggy
Drives: 2017 Camaro SS 1LE
Square setup for daily
Since i plan to get a 2nd set of wheels anyway as track use trashes wheels. Wondering if anyone has gone to a square setup for daily on their 1LE?
Maybe even a downsize for more tire options?
Considering 285/35 on 19x10. Assuming there is brake clearance.
'17 Camaro SS Coupe Red Hot |1LE|PDR|
3/24/17 Ordered
3/31/17 3000 Status TPW 5/1
4/24/17 3400 Status TPW 5/1
5/03/17 4200 Status Built!!!
5/05/17 4300 Status
5/15/17 4B00 Status
5/17/17 5000 Status
5/19/17 6000 Status
rdoggy is offline   Reply With Quote
Old 04-10-2017, 11:18 AM   #2
7stringtheory
Drives: 2017 Camaro 1SS 1LE
My personal opinion is you should use the square setup for track use, so you can rotate the track tires, because as you said, track use trashes them. There are already pretty extensive threads on people theorizing and experimenting with 19" square setups for the 1LE.
7stringtheory is offline   Reply With Quote
Old 04-10-2017, 11:19 AM   #3
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I haven't done it yet, but after researching I think I'll go with 295/30R20's.
Old 04-10-2017, 11:28 AM   #4
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
See my build thread for more info. I have a track setup (305/30/19 Trofeo Rs all around)
glamcem is offline   Reply With Quote
Old 04-10-2017, 11:35 AM   #5
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
I'm on 295/30's square. Nothing major to report, great on a backroad or road trip.
I just put 1100 miles on the car this past weekend going to visit friends in Asheville via the tail of the dragon! 295 square doesn't have a huge impact on the car's handling balance, its still insanely stable and fun on the street or track; but allows me to rotate tires on wheels to maximize tire life (it helps my best friend runs a track prep shop and gives me a good deal on mount/balance!)
Provoste is offline   Reply With Quote
Old 04-10-2017, 12:29 PM   #6
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I assume this means no rubbing to report? What brand/model tire did you run? Stock wheels/offsets?
Old 04-10-2017, 12:36 PM   #7
Provoste
Provoste's Avatar
Correct- no rubbing. Bridgestone RE71R. OE wheels, no spacer.
Old 04-10-2017, 01:09 PM   #8
rdoggy
So you're still running 20x10 front and 20x11 back and having the tires swapped?
3/24/17 Ordered
5/05/17 4300 Status
5/15/17 4B00 Status
5/17/17 5000 Status
5/19/17 6000 Status
Old 04-10-2017, 01:16 PM   #9
Provoste
Provoste's Avatar
Yes, factory staggered wheels. Just saying swapping tires on wheels is an option if needed in the future. For instance, the rear tends to wear the centers quicker and the fronts tent to wear the shoulders quicker (my driving style).
Old 04-10-2017, 01:29 PM   #10
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
That is the set up I was looking at, too. Can you post a pic of each of the wheels to see how the 295's look? Thanks.
RUQWIKR is offline   Reply With Quote
Old 04-10-2017, 03:41 PM   #11
2004z06
2004z06's Avatar
Drives: 2017 HBM 1LE
Pictures would be great. Both of car and wheels.
2004z06 is offline   Reply With Quote
Old 04-10-2017, 04:12 PM   #12
glamcem
glamcem's Avatar
for daily use, you may also consider Michelin PS4S tires since it's available in almost all the sizes. Cheap, one of the best (if not the best) wet traction, and longer treadwear.. they're light too. I would go with 295/30/19 instead of 35 sidewalls
https://www.tirerack.com/tires/tires...Pilot+Sport+4S
Old 04-10-2017, 04:17 PM   #13
alpeltier
alpeltier's Avatar
Drives: Will drive a 2018 2SS White Redline
Send a message via Skype™ to alpeltier
Hello, I am just learning. What is a "square setup? Do you mean just like the regular tire size and wheels that comes on the 2SS Camaro ?
I would like to do this to my car when it arrives (2017 Garnet red SS 1LE).
I'd like to buy 4 black rims and the exact same tires that goes on the regular SS.
Anything mechanical standing in my way (differential etc...?)
al
alpeltier is offline   Reply With Quote
Old 04-10-2017, 06:17 PM   #14
Provoste
Provoste's Avatar
Here you go. No big surprise- a little bigger front sidewalk, a little smaller rear.
