Old 04-09-2017, 01:28 PM   #1
jaredkoby
Drives: Hyper Metallic Blue Camaro
Water somehow leaked into trunk, Radio doesn't turn on with car
This weekend, my 2016 camaro's radio stopped working, the sound was completely off (couldn't hear the blinkers) and the screen only showed black. The back up camera worked still, but the screen would return to black after. I checked the fuses and found 3/4-1 inch of water in the bottom of the trunk. The radio turned back on last night after about an hour of being off but then this morning it did not turn on at all. I drove intermittently, turning it on and off here and there but it never turned on again. Any suggestions to get the screen to turn on again? I checked the fuses and they all are snug and in all the way, and I also did the turn off the car, open the door, shut it, lock it and wait 5 minute trick but that didn't work. I don't have time to leave the car at the shop until next week, I just need a way to get the radio back on for an emergency trip on friday (I am a student and I have to get home this weekend). Please help.
jaredkoby is offline   Reply With Quote
Old 04-09-2017, 02:14 PM   #2
brettman
Drives: 2016 Camaro SS
Close the truck when it rains
It's a car not a boat, try to keep out of rivers or lakes.
If still running, Hum your favorite tune driving to school.
I hope that helps.
brettman is offline   Reply With Quote
Old 04-09-2017, 02:58 PM   #3
jaredkoby
I hope that helps.
Yeah the trunk was closed, the water was from a leak that the dealership will have to find and fix, nothing I could do to stop that, a couple of days without a cover because the wind blew it off and the trunk was full of water. But I don't care about that right now, I can mitigate that and watch any more, I just want my radio to work.
Old 05-31-2018, 06:52 PM   #4
thecamaroshadow
Drives: 2017 Camaro 2SS Purple Black
Did they find the leak? Where was it?
I have one too.
thecamaroshadow is offline   Reply With Quote
Old 06-01-2018, 02:27 PM   #5
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
I had a minor water leak in my trunk There was a section of the rubber seal on top that wasnt sitting on the pinch weld properly I had to fight it to go where i wanted but hasnt leaked since
HackSaw is offline   Reply With Quote
Old 06-14-2018, 03:21 PM   #6
thecamaroshadow
I also had a pinch. Happy to say the dealer replaced the trunk seal, and I no longer have a leak.
Old 07-16-2018, 09:24 PM   #7
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
https://www.camaro6.com/forums/showthread.php?t=534062 - I have a water leak too
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 07-17-2018, 11:37 AM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
You could try contacting OnStar. They may be able to reboot your MyLink system remotely.
Old 07-17-2018, 01:59 PM   #9
Giri
Check your fuses. This is what my fuse box looks like
Old 07-17-2018, 04:27 PM   #10
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
I hope that helps.
real nice contribution.
OP; i had a small leak into my trunk too, it was the seal.
hitmix300 is offline   Reply With Quote
Old 04-24-2021, 07:02 PM   #11
Cf_maro1991
Drives: 2017 Chevrolet Camaro 2lt RS
Any updates I just encountered this?
Did you get this fixed I just encountered this problem
Cf_maro1991 is offline   Reply With Quote
Old 01-14-2022, 12:05 AM   #12
Omar1
Drives: 2016 2SS Red Hot
Would you mind sharing your fix for this? Recently encountered the same problem. Replaced the entire fuse box?
2SS Red Hot 6 Speed, NPP, MRC, 5 sploke black low-gloss, glow-tie
Omar1 is offline   Reply With Quote
Old 01-14-2022, 06:09 PM   #13
Rock-It Man
There are a couple of common causes of water in the trunk.
#1: Sunroof drain hose uncoupled in trunk.
#2: Wire harness pinched in trunk rubber seal.
leak, mylink, no sound, radio, water damage
