![]() Drives: 32 Ford 55 Nomad 69 Ve 14 M5 17 ZL1 Join Date: Dec 2016
OK!! ENGINE DIED AT STOP LIGHT
Had been out driving... Normal conditions and normal driving. Pulled into Shell and filled up on Super VPower. Pulled out to stop light and motor idled rough for 5 secs or so and motor died. Started it back up and it tried to die but I kept revs up and got the green light. Drove a mile to next light and the idle dialed in at 600 RPM... Put 50 miles or so today on it with no,problems...
Any thoughts? |
![]() Drives: 2017 ZL1 Nightfall Convertible M6 Join Date: Nov 2016
Fuel issue. Run unless repeats.
![]() Drives: Big Brown Join Date: Dec 2016
Agree...
Sounds like trash in the fuel...did it throw any codes or check engine light? If not then I wouldn't worry too much. |
Envy
Drives: 2011 SGM 2SS/RS - Black hood/hockey Join Date: Aug 2011
Is there a fuse pull for the fuel map in this car yet?
Retired from Car mfrs....
Not necessary on gen 6 - totally diff software and ECU..... |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2016
could be a bad batch of gas and/or filled up at the wrong time (tanker filling up pumps) it mixes the tanks and you get all the garbage clogging lines/ filter up. when you see a tanker at the station dont go there.
#7 |
Bring It
Did you pull in on fumes haha?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
#8 |
2nd tank of gas... Both the fuel from dealership and this fuel up were Shell VPower. No codes... No alerts... Just shut off after 30 seconds or so of RPMs going up and down...
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
My whole life that is my motto after a friend of mine got a full tank of water.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#10 |
![]() Drives: Getaway Special Join Date: Jan 2013
It's a False Flag event.
Sip:
#11 |
Built and Tuned By Hhp
Drives: . Join Date: Mar 2017
I have said this before but everybody ignorantly ignores the warning. But the base map from GM has issues, my specific car detonated while doing baseline dyno pulls on 93 pump at damn near sea level. I'm not supprised people out there are experiencing issues, but I'll say this one last thing on he matter. Ignoring it won't make the problem go away!
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: X-15 Velocipede Join Date: Mar 2008
High probability of condensation build-up, water in fuel.
Give her this medicine, and call me in the morning...
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
update?
ZL1::J-E-T-S JETS JETS JETS |
#14 |
I refilled the tank with about 6 gallons of different fuel and am going to add the gas treatment. It has not happened again either
