04-05-2017, 03:43 PM | #1 |
1LE Front Camber Adjustment
Before my first track event I took my car to Cobb Tuning Plano to get a track alignment and was told that the front camber can not be adjusted without camber plates, which Vorshlag hasn't released yet for our car. Does anybody know a way to adjust the camber without plates?
04-05-2017, 03:57 PM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The strut mount bolt holes are elongated like most 2-bolt strut mounting methods to allow a limited amount of camber adjustment. This is why GM is able to publish recommended Street and Track alignments for the 1LE's and ZL1. Most owners seem to be getting roughly -2.2° max front camber with the factory hardware.
Cobb must've had a brain fart moment; they're usually good with the obvious stuff like that. The mounting method is nothing new.
04-05-2017, 04:00 PM | #3 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Yea, the lower strut mount bolt holes are elongated for this purpose.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
04-05-2017, 04:02 PM | #4 |
I was shooting for -2 in the front and -1 in the back so I'm good with that max spec. Thanks for the info, I'm going back to Cobb and making them give me an alignment for free.
04-05-2017, 04:11 PM | #5 |
Hot Dog
FYI, the GM Track alignment is -2.0° front and -1.5° rear camber with 0.1° total toe front and rear. Page 18 of the Performance Supplement manual.
04-05-2017, 06:34 PM | #6 |
Drives: ZL1 1LE Join Date: Oct 2016
I'm running -2.4F and -1.6R on my car. No camber plates needed.
04-05-2017, 07:12 PM | #7 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
^^ that's what I am planning to do next (-2.4 front and maybe -1.8 rear to get rid of that slight tire rubbing). I am currently at -2.2 front and -1.6 rear . Since I wasn't sure about the fitment with 5mm spacers, grinding and new 19" wheels I didn't want the guy to add any more than -2.2.
With that said, I can also confirm that for that amount of camber, camber plate shouldn't be needed (if you are planning to run OEM 20" wheels). I also need to add, when he first untightened the camber bolt we saw -2.6, -2.7 camber then we backed down
04-05-2017, 10:53 PM | #8 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
I went for my track alignment today... When they adjusted the rear camber to -1.5 degrees, they couldn't get the toe anywhere near .1 degrees on the left side... The max it would go was around -.7 degrees... I crawled under the car to verify that it was maxed out... I need to order toe links...
04-05-2017, 11:22 PM | #9 |
hmmm you definitely shouldn't need toe links, there is a lot of room to play back there. Most shops will use 16ths for toe instead of degree's, not sure why GM does that. I'd shoot for 1/32 on each side, giving you a total of 1/16 toe in for the rear. Generally a good starting place.
My current set up is: F: -2.4* camber, -1/16 toe (out). R: -1.6* camber, 1/16 toe (in)
04-06-2017, 12:11 AM | #10 | |
04-06-2017, 05:28 AM | #11 | |
Drives: 2017 SS 1LE Join Date: Oct 2016
2017 SS 1LE Hyper Blue - PDR - TSSHKX
2017 SS 1LE Hyper Blue - PDR - VBHF63 |
04-06-2017, 06:02 AM | #12 | |
Here's why GM uses degrees instead of distances: degrees are independent of wheel/tire size. If a different size wheel/tire is applied to the vehicle a distance toe setting would have to change to get the same alignment. A degree specification gets rid of this wheel/tire size relativity complication and becomes more absolute - protects for whatever wheel/tire is applied to the car. Kind of like the difference between relative humidity and dew point. Dew point is an absolute measurement of water in the air (what your body feels) while relative humidity changes with temperature (needs 2 inputs vs. 1 absolute).
04-06-2017, 06:24 AM | #13 | |
Most manufacturers use 0 to some small amount of toe-in at the front for the bushing pre-load reason. Here's a sample compilation list (sign conventions: positive = toe in for toe, negative = top of tire in for camber):
04-06-2017, 10:13 AM | #14 |
*I would also highly recommend you guys (as in any and all 1LE owners) go get your alignments checked, even if you keep the street settings. Mine was a decent bit out of wack from the factory and caused some horrible driving issues (lots of tram line). I remember a few other members posting the same PSA.
