Old 04-04-2017, 06:25 PM   #1
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
K&N Air Intake System Squeezes Some of the Last HP from the 2016 Camaro SS 6.2L
K&N Engineering, Inc. News
The increase in horsepower can be credited largely to the oversized conical air filter
The Generation V 6.2L small block V8 is the latest chapter in the long, historic legacy of the small-block Chevy engine that stretches back to the mid-1950s. The latest design provides the 2016 Camaro SS not only with immense performance but unheard of efficiency from such a powerful engine.
The 455 horsepower LT1 is similar in architecture to the LS family of small-block engines which it superseded, but with a unique aluminum block casting and aluminum cylinder heads, oiling system, and an aggressive 11.5:1 compression ratio. It also incorporates advanced technologies such as direct fuel Injection and continuously variable valve timing. And unlike many other auto manufacturers, GM believes there is plenty of development left in the traditional two valve push rod V8 and proves it with each new engine.
To draw an adequate volume of air an entirely new intake manifold design was developed, which provides a straighter path into the combustion chamber. With as much time and development effort that GM engineers put into the LT1, one would assume that the intake system would leave no opportunity for improvement. But it does. There’s an additional way to improve the performance of your 2016 Camaro SS: the K&N 69-4534TP air intake system, which has been chassis dyno-tested proven to deliver an estimated 15.16 rear-wheel horsepower gain over an otherwise stock 2016 Camaro SS.
The K&N 69-4534TP air intake system replaces the restrictive factory air filter and air intake housing on the 2016 Camaro SS. K&N AirChargers significantly improve incoming air flow as well as reduce turbulence in the intake tube.
Installation of the K&N 69-4534TP is a snap and can be completed in less than a Saturday morning
The air intake first enters a chrome capped K&N high-flow air filter sited within a heat shield that’s installed into the original air box space. A bulk of the horsepower increase can be credited to the over sized conical air filter manufactured from multiple layers of oiled cotton filter media - which offers less resistance than traditional filters. The multi-layered red cotton material also filters out micro-particles that could damage your engine, to help ensure a long engine life. Each design is verified through K&N’s in-house filtration testing lab, which adheres to ISO 5011 standards, ensuring that your K&N filter provides high airflow without putting engine protection at risk.
Air is then directed through an aerodynamically-verified polished aluminum intake tube into the engine’s throttle body for an estimated 15 horsepower gain. The intake tube includes fittings for the factory mass air sensor and crank case vent hose. Best of all, the K&N 69-4534TP air intake system can be installed in 90 minutes or less with simple hand tools
In addition to more power, this air intake system improves engine sound with more aggressive and deeper acoustics during acceleration.
And once you’ve installed your K&N cold air intake system you’ve eliminated the need to buy another air filter for the life of your covered 2016 Camaro SS. The only maintenance is a service you can do yourself in no time at all. At intervals of 100,000 miles (depending upon your driving conditions) use the K&N 99-5000 recharger kit to clean and refresh your air filter, preparing it for another 100,000 miles of driving. The K&N air filter you purchase is designed to last for the lifetime of your vehicle, which K&N guarantees will perform for up to 10 years or 1,000,000 miles without requiring replacement.
The K&N 69-4534TP cold air intake is designed for the following vehicles:
2017 CHEVROLET CAMARO SS 6.2L V8 Fuel Injection - All Models
2016 CHEVROLET CAMARO SS 6.2L V8 Fuel Injection - All Models
Please email me with any questions or to place your order. lbowen@stillen.com
?utm_source=camaro5&utm_medium=referral&utm_campai gn=lauren
Team STILLEN is offline   Reply With Quote
Old 04-06-2017, 08:31 PM   #2
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
This is the #1 Intake its a shAme not mAny people know this.
MOST people I know have the 63-3092 and have sick gains. LmAo even rhe drop in out performed some of the big boys
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 04-06-2017, 09:14 PM   #3
enzia35
Drives: '16 Garnet Red 1SS
Living in Lubbock, I'll pass on K&N.
'16 Camaro 1SS
'18 Miata GT
Old 04-07-2017, 07:32 AM   #4
Waiting46
Drives: 1981 silver corvette,Hyper Blue 2SS
Dynos?
Waiting46 is offline   Reply With Quote
Old 04-07-2017, 11:53 AM   #5
Team STILLEN
Drives: Varies
I wish there was a "like" button for your comment. Thank you!! Are you interested in a quote or purchasing one?
Old 04-07-2017, 11:56 AM   #6
slick3
Drives: Garnet Red - 20 ZLE
need some real work numbers. As far as I know RF has been the only one tested to show any gains at all.
slick3 is offline   Reply With Quote
Old 04-07-2017, 02:19 PM   #7
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Mind sharing some of your sources?
Old 04-07-2017, 02:55 PM   #8
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
What are these "sick gains"? I'd love to know...
2017 SS 1LE
1LEMATT is offline   Reply With Quote
Old 04-07-2017, 05:23 PM   #9
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
I have used K&N before, but I would like to see the fuel trims and some independent dyno testing to go with this. Proof of the pudding is eating it, my dad used to say!
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 04-07-2017, 05:31 PM   #10
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Sick gains of dirt/dust?
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 04-07-2017, 11:32 PM   #11
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
I got it!
Blk16SS is offline   Reply With Quote
Old 04-08-2017, 07:48 AM   #12
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I can't honestly recall the last time K&N was the leader in anything. They aren't bad, don't get me wrong but, they just cater to a different crowd. It's like getting some old school flowmasters on your car. Sure, it'll sound great but, they won't flow worth a damn. The newer ones are a different story, however.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 04-08-2017, 11:36 PM   #13
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Well. They all look the same.
Big filters. Big box....Big Tubes...
And almost $200 less...........
How do you test it. If I bought one I am NOT going to spend hundreds on dyno pulls and tuning just to make a web crowd happy....even though I love you all like brothers. ")
Old 04-09-2017, 09:36 PM   #14
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
http://www.knfilters.com/search/prod...gBEiQAdxotvDK0
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
camaro intake, intake, k&n, k&n 2016 camaro intake, stillen
