![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
Flex Fuel Kit & Wideband O2 Installed
Now its time to get it tuned...
Drives: Camaro Join Date: Feb 2017
Thread gets 2/10. Sideways pic, and no pic of the flexfuel kit. Will not read again....
J/k, I want to do the same. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Nice
How did you hook up power and ground? Fuse panel ? I'm about to install my aem wideband and I've never done it before. Some install details and or pics would be greatly appreciated |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Nice
Why is your check engine light on ?
I haven't done it before either so I let a shop do both installs. Wiring makes me nervous..
#7 |
#8 |
#9 | |
For a permanent install, I'd run a nice gauge wire like 12 or 14 to the ground in the harness as close to possible without looking all nasty. This will help with any ground float issues. Note I did NOT have any ground float issues till I tried to data log, the out put of the device is a set voltage from ground, but ground is up say .8 Volts cause of float... Don't get all confused and follow the 2nd to last paragraph and all is well.
#10 | |
It will only be a temporary install |
#11 |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
I tied into the HVAC connector under the passenger side glove box for power and ground, O2 sensor out the sound tube delete plate from my rotofab
#12 |
Set it up on Lambda, Tim wont have any of that AFR non-sense
![]() Where did you get the gauge pod, looks nice bud |
#13 |
funny thing about lambda is max rich power and max lean power is different (slightly) for:
gas, E10, E85... It was hard for me to get use to Lambda. Pure Gasoline Stoichiometric 14.7 1.000 Pure Gasoline Max Power Rich 12.5 0.8503 Pure Gasoline Max Power Lean 13.23 0.900 E10 Stoichiometric 14.08 1.000 E10 Max Power Rich 12.0 0.8523 E10 Max Power Lean 12.7008 0.9020 E85 Stoichiometric 9.765 1.000 E85 Max Power Rich 6.975 0.7143 E85 Max Power Lean 8.469 0.8673 http://www.hotrod.com/articles/wideband-oxygen-sensor/ You can see you can get away with a lot richer on E85 and still make max power
#14 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Lambda or nothing! LOL
