Old 04-03-2017, 07:47 AM   #1
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Is 93 Octane available?
Is 93 octane available in your area? I'm having hard time finding 93. 91 is readily available at almost every station, but not 93. I wonder how this affects performance? The manual says to use 93 or 91 if 93 not available. If the car is tuned to 93, should it be adjusted to 91 to get better performance?
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 04-03-2017, 07:52 AM   #2
speedyman
Drives: ATS4
Everywhere in PA.
speedyman is offline   Reply With Quote
Old 04-03-2017, 07:54 AM   #3
HyperBlueX2
I have a mix of 93 and 91 around me.... depends on the stations brand. I consistantly use one gas station. Their quality of gas stays high and always makes my Grand National happy, which is happiest with a true 93 octane with the tune it has. They happen to be a Sunoco station.
Old 04-03-2017, 08:39 AM   #4
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Virtually every pump in TX. Same with E85 if I'm not mistaken. I've never inspected it but often see a yellow pump.
Infern0 is offline   Reply With Quote
Old 04-03-2017, 08:47 AM   #5
Burnt Rubber
Burnt Rubber's Avatar
Drives: 1991 1LE & 2017 Red Hot ZL1
93 is available all over Long Island NY. I have to use it in my GT350 and Denali. And I will be using it in my ZL1 whenever it gets here. I haven't checked into it,can we use E85 in the ZL1?
Burnt Rubber is offline   Reply With Quote
Old 04-03-2017, 08:57 AM   #6
shaffe
Drives: 21 Bronco
93 is available at every station I have stopped at here in the suburbs of Chicago
Lets keep it simple. ..
Old 04-03-2017, 09:42 AM   #7
psalmon123
Drives: 2015 Z07 2017 ZL1
Fill it with 91 and put in a bottle of 104 octane boost every or every other tank (depending on how many gallons your adding). It works great in my HP boat. That is what I'm going to do.
psalmon123 is offline   Reply With Quote
Old 04-03-2017, 09:46 AM   #8
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
Highly available here
rvnmaniac is offline   Reply With Quote
Old 04-03-2017, 12:09 PM   #9
Shadow77
Shadow77's Avatar
Drives: 2017 ZL1
+1
We had a station not too far that sold 94 as well. Haven't been there in awhile though.
Shadow77 is offline   Reply With Quote
Old 04-03-2017, 12:15 PM   #10
Burnt Rubber
Just make sure the 104 doesn't have lead in. I still have older cans of it with lead added.
Old 04-03-2017, 03:03 PM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
The car will automatically adjust to the 91 octane, that is all we have in AZ. It will run fine on 91, it will be just a little better on 93. I am speaking from a 5th gen perspective but I think it will be the same in the 6th. Also, in the 5th gen they said you can run 87 but could possibly harm the engine. There is a really good thread on this in the 5th gen ZL1 section.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 04-03-2017, 03:22 PM   #12
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
No 93 at a standard station here in SoCal (I believe it is all of California, but I am not an expert about up north, so I won't say for sure),...at the racetrack you can get some good gas lol...we probably have some of the worst gas in the country here. Even some stations that say they are 91 octane...are not...pretty bad.
SoCal Racer is offline   Reply With Quote
Old 04-03-2017, 05:11 PM   #13
SSport16
SSport16's Avatar
Every pump here in my area of NC has 93, haven't seen 91 in a long time.
Old 04-03-2017, 05:20 PM   #14
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
I remember when Sunoco had 94 octane !!!!!!
mr02Z/28 is offline   Reply With Quote
