SNSTRSS
ECM Part Number?
I'm looking for the correct part number for a 2016 6.2 2SS A8 ecm. I see possibly 12672537 but also see 12676230. Trying to see if there is a way to have a spare one to use for stock only setup. Any information would be greatly appreciated. Thanks
2016 Black Camaro 2SS A8 NP
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Almost positive you can't do that but I will let the pros chime in as to why you can't.
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Correct was told it will not work.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
![]() Drives: 2015 SS 1LE Join Date: Feb 2017
I was told otherwise by a Service Manager...
2015 Summit White SS 1LE: TSP Baldeagle, RotoFab, Speed Engineering LT's/Full 3”, E85: 480rwhp 👎🏼
SNSTRSS
I would like to know what they had to say about doing this. Can you elaborate? Or anyone else chime in.
Below is a quote from Ted at Jannetty racing i hope he does not mind.
You can not swap ecms with our GM knowing as you must have a GDS connected to GMs server to activate and or synchronize a new ECM in your car. If you synchronize one computer then try and put back the other the car will not start or run. Here is a link to this thread. http://www.camaro6.com/forums/showth...ight=Spare+ecm
#7 |
Like JFM said, you have to be connected to a GM server, but a new ECM can be programmed to your car. Just not as easy as ordering one with your VIN anymore...
