Old 03-30-2017, 06:51 PM   #1
keon718nyc
DIY - LED Reverse Lights MOD
Well after reading another thread and wanting to change out my Reverse LED's for some time now i figured i would post this for those that are interested without having to spend more then $20-$30 or even less total. I give all the credits to TonyNo & Nookz for this one just wanted to post clear pics on the before and after as well as what you will need ect.
1. A set of LED Reverse Bulbs (i got mine from Amazon) $15-$25. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2. A set of needle nose pliers to cut and crimp the wire down to the bulb connections front and back as shown in pictures below.
3. Two 2.2k Ohm Resistors, 1/4 W, 5% - A pack of 25pcs goes on Amazon for $5.77 or another forum member mentioned Radio Shack if you still have one around you for about .75 for 2pcs! - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Resistor wire will need to be cut to fit over the LED Bulb wire as in sample pictures below. The resister used in the reverse lights is just to compensate for the reverse switch that leaks current when not closed as pointed out from another member. Enjoy the pics and money saving on this awesome DIY MOD!!!!
Old 03-31-2017, 10:18 AM   #2
MANNAXMAN
MANNAXMAN's Avatar
Nice write-up, keon. After seeing TonyNo's post and getting more detail from Nookz a little while back, I knew I wanted to go this route for the LED conversion.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 03-31-2017, 10:31 AM   #3
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
Any heat issues from the resistor?
FLYNNZL1 is offline   Reply With Quote
Old 03-31-2017, 10:45 AM   #4
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
very nice!! i need to do this lol
cmeJATT is offline   Reply With Quote
Old 03-31-2017, 11:22 AM   #5
keon718nyc
None, works flawless no heat at all. I checked a few times last night to be sure on it. For a few bucks and 15 minutes or so this was the best mod by far for what its worth!!!! Thanks everyone, Glad i can share this with you guys!
Old 03-31-2017, 11:44 AM   #6
tecboy
tecboy's Avatar
i assume each led needs a resistor installed across the leads...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 03-31-2017, 11:54 AM   #7
keon718nyc
Yes exactly, All you need is 2 of them. If you can find them by piece i would imagine them to be about 20cents each but only i can find a 25pk on Amazon for $5.77. I may just give the rest of my resistors away to some forum members looking to do this LED conversion next week when i have some time.
Old 03-31-2017, 11:54 AM   #8
FLYNNZL1
Drives: Man
Thank you for sharing, does the resistor go on a certain way?
Old 03-31-2017, 12:00 PM   #9
keon718nyc
To be honest i followed this picture attached and just kinda routed it the same way. I am thinking its a remote to ground or positive to ground. Either way if it is not in right and both bulbs are in the sockets and you will see a dim glow from them when threy are off meaning the resistors are not in the correct way. Here is a better pic from a forum member that i followed the same leads looking at the photo the farthest outer pin/wires is where to connect them -
Old 03-31-2017, 12:04 PM   #10
tecboy
tecboy's Avatar
thanks....there are actually a couple radio shacks still open in town..looks like they have them for about 75 cents for 2...
Old 03-31-2017, 12:06 PM   #11
keon718nyc
That is perfect!!! They closed all the radio shacks here in my area but good find to those that have one still around
Old 03-31-2017, 12:08 PM   #12
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Wait so... you don't have to pull entire taillight off of the car??
Also... you don't have to drill hole to mount those big heat sink looking resistors?
If so this is the mod I need!
Could I send you my address? I don't have any radio shacks around here.
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 03-31-2017, 12:13 PM   #13
keon718nyc
Lastly, I'd like to see exactly how to put the tiny resistor on the bottom of bulbs, I'm not sure how you do that... does it stick on to it? Do you wrap it around?
No need to pull the tail lights off at all and no drilling whatsoever! Simple as changing the bulb is far as it goes Just wrap the resistor around the best you can and as you plug them in the resistor wire will move down and the contacts of the resistor and bulb should tuck in securely in place. it took about 2 tries as i didn't have my wires on tight but a needle nose pliers worked wonders for that.
And yes, shoot me your address through a PM as i would be happy to send a pair out tomorrow or Monday at the latest and help those in need.
Old 03-31-2017, 12:29 PM   #14
Adrian97c
Adrian97c's Avatar
I been holding off on this for along time... so glad I did! Thanks for this!
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
