![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
Anyone running an Elite E2-X catch can?
Just looking for opinions on this setup. I want to do the catch can the same time as the P1, now it's just down to which one.
2018 ZL1…Many mods to come
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
The Elite E2-X is the most effective in air/oil separation on the market. And for your LT1 based GDI engine, you need to address all ingestion. Most catch cans only trap from 15-30% maximum, and you can test yourself to see to wade through all the opinions. Let us know if your engine has the black plastic square container mounted tot he passenger side valve cover with the clean side lines running to it. If yours does, you do NOT need our clean side separator as that factory unit does a pretty good job (finally) but the dirty/foul side needs this.
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
^^I am not sure if it was your product or not, for some reason I am thinking so. But do you make one for supercharged applications? I had a mishimoto one prior to my Maggie install, and ended up going up for sale (as the hoses only was formed a certain way) do you have a rectification for this? if so, would there be a guide for install? I know that I had to modify one of the lines upon install which now everything has a place and needed to know where to start deviding this out. or if there will be loss of PSI somewhere down the line.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
#4 | |
![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
Would be great if you would post up pics or install instruction for supercharged setups (maybe even including them with the product when you ship it )... I get asked 3-4 times a day on how to route the lines and where to put the check valves.. ![]()
That was my next question.
#6 | |
![]() Drives: Summit white 2SS Join Date: Feb 2017
Well I was going to get the mishimoto catch can this month but I'll be installing the Maggie next year so I don't want to waste money. Thanks for the input
2016 summit white SS with 2300 Maggie Heartbeat, Rotofab CAI, kooks headers. Michelin PS4S tires.
#7 |
HYPER SS
bump for Elite's questions????
Ordered: 1/15/2016
#8 |
The Elite Engineering E2-X and E2-X "Ultra" system provides constant suction on the crankcase during both boost and non boost being the next best thing to a belt driven vacuum pump (which is the best solution but will not last on the street). This has been extensively tested by Turbonetics on their house turbo builds up to and in excess of 1000 HP.
The Gen 6 is a little bit different, but here are the illustrations from Turbonetics on how to properly configure the system on a LS based V8. This is the only system that addressed all of the issues aftermarket turbo systems experience not only eliminating crankcase pressure from the start (VS let it build and vent) and also removes the contaminates from the crankcase that in a "vented" system that are allowed to settle and mix with the engine oil when in boost. ![]() ![]() ![]() The Elite system uses the intake manifold to evacuate when in non-boost, and the turbo inlet(s) for suction when in boost. The high quality checkvalves will automatically open and close to default to the strongest suction source available providing full time evacuation. The Elite billet clean side separator deals with any fresh/clean side ingestion and the Ultra model is designed for power up to and beyond 1000 HP. |
#9 |
I'm getting ready to install my E2 on my Edelbrock setup.. I'll post pictures as I go.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
#10 | |
#11 | |
HYPER SS
Nice!
Ordered: 1/15/2016
#12 |
#13 |
Install instructions are in my Supercharger install thread starting at post 139.
http://www.camaro6.com/forums/showthread.php?t=489086
#14 | |
