![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
UPDATE! 5000 RPM Limit MYSTERY SOLVED!?!?
(2017 ZL1 M6) After getting the car broken in and past 1500 miles I decided to do some 0-60 pulls. The car hits the RPM limiter at 5000 RPM's. The car was advertised to be able to go 0-60 in first gear. Its not even close. First cuts off at 5000 RPM's and so does second. It takes all of first and second to get 0-60 time. This is not like the car cutting power for traction control, this is different and like hitting a wall. I checked both the Tachometer on dash and on HUD display. They are in dead sync. I went and talked to service tech at Chevy dealer and ask about possible lag with tach and not being in sync with actual engine. He said rev limiter and tach and hooked to same sensor, so thats not the issue. I'm not getting any error code, so a little confused where to go. Anyone else encountering this? Any advice?
04/06/2017- I took it in dealer and technician looked at it. It is not showing any codes and he couldn't find any service bulletins about it. He checked a couple of things and everything checked normal. So, I took technician with me on a ride and he had laptop connected to car. Sure enough, in first gear at WOT it totally cut power at 5600 RPM. I was actually relieved and he was able to capture the data. They are discussing with Chevy Tech support and it has been made a priority. They are bringing in an Area Specialist in the next couple of days and I will take the car back up there when he gets here. Also, several of you guys suggested ECM refresh or computer related. Local dealer can not refresh codes without Chevy being directly involved. I will keep you updated. I think it has to be simple because it hasn't shown any other symptoms or issues.
![]() Drives: 2017 ZL1 M6 Join Date: Mar 2014
First off that sucks! Sorry man.
I haven't heard of this before. Possibly like the governor setting for top speed? Have you asked if computer tuning would fix the issue? |
The Black Emerald
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS Join Date: Sep 2011
Don't worry, it'll happen, closer to 5k miles it seriously started feeling different, now it actually backfires with the popcorn pops now and then yes I've hit 61/62 in first now, give it some time to "wake up" as I've seen others say, I've got 7040 on mine as of today.
Exactly like a governor setting. They are researching at dealer, but can't do much without me leaving the car. Chevy will not even discuss with them unless the car is at the dealer and "hooked up to computer"
#5 | |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
Does this car have a valet mode? Would be cool if we could set it like this when we let other people borrow the car, (or the wife lol)
2014 ZL1 Camaro
1969 Camaro |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
Have you tried accelerating slower to eliminate the possibility of Tachometer lag? Just use say half throttle or only feed in more throttle when needed to actually go faster. You might be getting enough wheel spin that maybe it's the traction control system intervening.
Do you know anyone with HP Tuners that could data log a run and actually see the real data from the ECM?
#8 |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
It is probably limiting you to either higher miles before opening up or the car is not fully warmed up. Relax and have some patience.
#9 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
If you are truly hitting the rev limiter at 5000 something is wrong.
#10 |
It hits the rev limiter EVERY TIME I do a 0-60 run. It's not a Traction Control issue as it happens at exactly 5000 RPM every time. Not just once in a while. However, If I'm just going down the highway and floor it, it will go above 5000 RPM.
#11 |
HAMMER PILOT
That doesn't make sense, maybe a gear issue?
#12 | |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
Is your motor cutting out at 5000 rpm or just won't pull any more rpm's?
#14 |
Both, It cuts out like it hit a wall (rev limiter) and won't go past 5000
