![]() Drives: 2013 Corvette Grand Sport Join Date: Jan 2015
Flat Tires on 1/LE
In addition to the can of Goop that plugs the tire on a temporary basis, is there an air compressor in the 1/LE trunk?
Yes. Where a spare tire would be is the tire kit. Inside is the temporary sealant and a small compressor for reinflating the tire.
Can the air compressor be used to keep healthy tires properly inflated with air at the recommended tire pressure?
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
![]() Drives: 2017 Camaro SS 1LE Summit White Join Date: Jan 2017
Just a question. Can we buy a spare and jack to replace the fix-a-flat and compressor?
It seems like it might provide peace of mind. |
#6 | |
![]() ![]() Drives: 2014 2SS/RS 1LE Join Date: May 2013
There really appears to be no good alternative anymore, the fix a flat stuff will get all over the inside of your wheel rim and could affect balance, a spare will take up already limited trunk space and run-flat tires are extra expensive. Since fewer and fewer people these days even really know how to change tires anymore they just assume everyone is going to call for a tow truck.
#7 |
![]() Drives: Mitsubishi Evolution X Join Date: Nov 2016
Carry a full size spare in the back seat.
#8 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
![]() It's best just to carry the stock fix-a-flat kit and add a tire plug kit.
#9 |
I have one PM me.
#10 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Nope, three tires will fit in the backseat and one in the trunk. I've done it a few times in my 5th gen and once in my 6th gen.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
I used the air compressor when I had a slow leak in a rear tire.. worked great and the included gauge was accurate.
Did not use the fixaflat as I heard that makes the tire hard to repair. |
