Old 03-26-2017, 12:28 PM   #1
Red1Le
Drives: 2013 1Le
P0131???
Got this code yesterday car has 7200 miles full Kooks catless exhaust for past 1800. Has anyone else had a 02 sensor shoot it's wad this early on yet? Cleared code hasn't came back on going to hook it up to the HP tuner tomorrow to see what sensor is seeing.
Red1Le is offline   Reply With Quote
Old 03-28-2017, 08:08 AM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Possible causes Faulty Front Heated Oxygen Sensor (HO2S) Bank 1 Front Heated Oxygen Sensor (HO2S) Bank 1 harness is open or shorted Front Heated Oxygen Sensor (HO2S) Bank 1 circuit poor electrical connection Inappropriate fuel pressure Faulty fuel injectors Intake air leaks may be faulty Exhaust gas leaks
Read more: https://www.autocodes.com/p0131_chevrolet.html
Ventmaster is offline   Reply With Quote
Old 03-28-2017, 04:00 PM   #3
Red1Le
Drives: 2013 1Le
Just in case anyone ever runs into this since no one had much info to share. Hooked the data reader up to the car checked the volt readings of all 4 sensors. 3 were reading up to 0.9 volts and bank 1 (driver side front) was reading 0 to 0.005 volts. Pulled sensor replaced, cleared code, and rechecked voltage now reading up to 0.9 like its supposed to. Car only has low mileage only thing I can think caused failure was I got dealt the short straw from GM.
Old 03-28-2017, 05:33 PM   #4
PRAY
PRAY's Avatar
Drives: 2016 2SS
Good work. Thanks for figuring this out.
Old 03-28-2017, 07:57 PM   #5
glenB
Drives: Chevrolet Camaro SS
How is a failed sensor GMs fault if you changed to headers?
Why is your O2 voltage reading so high? .9 indicates that the system is rich is this all the time, only cold, while driving, was the sensor black with soot or white to grayish?
I ask because you may have fixed the failure but not the cause of the failure
glenB is offline   Reply With Quote
Old 03-28-2017, 09:27 PM   #6
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
I believe he was saying that it would fluctuate up to a max of 0.9 not steady state at 0.9. I wouldn't stress about why it failed. It could have gotten stressed (wire pulled, dropped, etc) somehow during the swap and finally gave out.
EFI Tuning is offline   Reply With Quote
Old 03-28-2017, 09:28 PM   #7
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Just to confirm, up until now, your catless cooks didnt throw any codes? I want to get them but I don't want to have to tune the car and void the warranty.
marknagy13 is offline   Reply With Quote
Old 03-28-2017, 09:36 PM   #8
TJay74
Headers will need a tune no matter what, catless will also require a tune no matter what as the rear O2 sensor codes will have to be turned off.
Most headers move the front O2 sensor location further from the engine and can affect how long it takes the sensor to "light off" which will cause a P01xx code of some sort.
The rear O2 sensors only tell the ECM if the cats are functioning, so when you go catless those rear O2 will trip a code as well and will require the rear O2 codes to be tuned out.
Old 03-31-2017, 07:36 PM   #9
Red1Le
Drives: 2013 1Le
First off the voltage does no read .9 all the time it changes based on how much throttle/fuel you give it. Didn't say it was GM's fault simply said got the short straw no biggie bought the new one replaced. No issues fuel trims and AFR's look great.
Old 03-31-2017, 07:37 PM   #10
Red1Le
Drives: 2013 1Le
Exactly anything could have happened to it during install all part of modding a car.
Old 03-31-2017, 07:38 PM   #11
Red1Le
Drives: 2013 1Le
Yea I am catless and no there where no codes because the car has been tuned correctly to avoid them. Code came on because the sensor failed and that code is not disabled during tuning for that very reason if failure occurs.
Old 03-31-2017, 07:40 PM   #12
Red1Le
Drives: 2013 1Le
Just to add to the thread and update have drove the car about 400 miles since changing the sensor. No issues data logs look great.
Old 03-31-2017, 08:31 PM   #13
glenB
Actually it changes based on oxygen content or lack there of, irrespective of RPM or TPS.
The short straw "from GM" to be exact "Car only has low mileage only thing I can think caused failure was I got dealt the short straw from GM."
Have a nice day
Old 04-01-2017, 06:04 AM   #14
Red1Le
Drives: 2013 1Le
Lol you should go troll back on the mustang forums phuckboy
