Old 03-26-2017, 09:18 AM   #1
glovo
Drives: Camaro 2016 1LT RS
goodyear f1 asymmetric Question
My 2016 camaro 1Lt came with the goodyear f1 asymmetric 2 front a rear same size, the ss rear tire are bigger.
Im goin to buy the goodyear f1 asymmetric 3 and I was thinking if I should buy the rear ones 275/35ZR20 (rear) for better traction , tirerack is recommending me to do it but I don't have the ss
glovo is offline   Reply With Quote
Old 03-26-2017, 09:37 AM   #2
BluinSC
Drives: BVM 1SS
If you have had any traction problems yet I would stick with the same sizes you already have. You can always call and get the size you need.
I'm going to order the Extreme Contact A/S myself for my SS from there in the next week.
BluinSC is offline   Reply With Quote
Old 03-26-2017, 09:42 AM   #3
glovo
ever since i went to my second schedule maintenance they rotated my tires(all of them have the same size) and i been having traction issues so yea ina couple months im goin to change them
Old 03-26-2017, 09:58 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I believe your 6th Gen 1LT/RS came with 8.5" wide wheels front and rear. The 6th Gen SS models have 8.5" front wheels and 9.5" rear wheels. The TireRack consultant may not understand the difference. You will want to confirm the wheel size on your car before buying the wider tire. Goodyear's minimum recommended wheel size for the 275/35ZR20 is 9" so it is probably not a good fit for your car if your car has 8.5" wheels.
Old 03-26-2017, 10:12 AM   #5
glovo
Thanks I will look into this
