![]() Drives: Slow Join Date: Mar 2016
Did a couple 0-60 runs this afternoon
Both times the car bogged off the launch so I can definitely see 3.5-3.6 with the m6. Will possibly try a few more times tonight to get some mid 3's. They key that I'm not seeing in some of these online videos of zl1 m6 0-60 runs is that they are shifting too early. This car will do 61-62 in first gear. Don't shift before then and you'll get a sub 4 time easily.
2016 Toyota 4Runner
2017 Camaro ZL1 |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2009
Not too bad at all. Now take it to the track and translate those good 0 to 60 times into some good 1/4 times
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
I tried last weekend, best I could muster was 12.0@123. Too much chaos on green unfortunately.....2.2 60'
2016 Toyota 4Runner
2017 Camaro ZL1 |
![]() Drives: 2017 ZL1 Join Date: Dec 2016
I had the same issue with mine. Either bogged or spun. I'm not trying to bump mine off the rev limiter to get a good 0-60 time. Like big Dave said, let's see some 1/4 (or even 1/8) mile times.
2017 Camaro ZL1, M6, summit white
I plan on going back in the next few weeks. Best I was able to do was match my time earlier. It cuts too much power upon initial release of the clutch then starts hopping to about 30. But this also was with no burnout, only heat that was in the tires was from driving
2016 Toyota 4Runner
2017 Camaro ZL1 |
![]() ![]() Drives: 2018 ZL1 A10/2018 GT350R #JR603 Join Date: Jan 2017
I did 3.9 0-60 in my 2016 SS A8
#7 |
I did 3.9 in mine too but I also didn't spin.....makes a huge difference.
2016 Toyota 4Runner
2017 Camaro ZL1 |
#8 |
![]() Drives: Mitsubishi Evolution X Join Date: Nov 2016
#9 |
Lol......ok.
I think the key point of the thread is that the m6 zl1 has the ability to run a mid 3 0-60 time (based on the car's built in timer, so take that for what it's worth) with a good launch and little wheelspin.
2016 Toyota 4Runner
2017 Camaro ZL1 |
#10 |
Published times have rollout where the timer goes on first movement?
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
My 2016 2SS convertible A8..... GM published numbers.....12.5@115mph and 4.2 0-60 for SS automatic convertible.....
My ZL1 A10 with a mild launch and run..... GM numbers of 3.5 0-60 and 11.4@127mph for ZL1 A10..... much more available.... definitely .5 seconds more to lose on both.....if not .75 to a full second on full power run in the 1/4..... Last edited by HyperBlueX2; 03-26-2017 at 10:01 AM. |
#12 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
Every instance of the dash timer vs a real timer that I could find showed the dash timer was .1 to .2 seconds stingy, which is good in my mind. I'd rather it be consistently a little stingy than randomly blowing sunshine up my ass.
#13 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Agree 100%!
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#14 |
That's very impressive for a less than full throttle run. I've thought about trying that myself, but haven't yet.
