Old 03-21-2017, 06:03 PM   #1
guitarman8373
guitarman8373's Avatar
Drives: 2016 2SS Camaro fully loaded.
Re-indexing car window?
The only way to re-index my car window is to disconnect and reconnect the battery I assume?
My driver side window doesn't go up far enough and has been causing some wind noise since the last time I had to disconnect the battery to do some work.
In comparison to the passenger side window, it can go up maybe .25 inch more.
guitarman8373 is offline   Reply With Quote
Old 03-21-2017, 06:09 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Yup disconnect....
The negative battery cable is a simple 10 mm socket/wrench, right inside the little door.
Then roll up and down .....done.....
Old 03-22-2017, 10:27 AM   #3
guitarman8373
So when it prompts you to reindex you roll up first then down? Not the other way around?
Old 03-22-2017, 10:30 AM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Edited my post to be More clear.....
Old 03-22-2017, 04:52 PM   #5
guitarman8373
Thanks!
Old 01-01-2018, 03:54 PM   #6
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
You can pull fuse F9 in the trunk as well. Note that you have to still turn the car off and back on. It's the 30A fuse in almost the upper left.
trm0002 is offline   Reply With Quote
Old 01-01-2018, 07:10 PM   #7
jwober
jwober's Avatar
Drives: 50th Anniversary 2SS M6 Convertible
Ignition ON. Doors closed.
1.Starting with the window completely UP, press and hold the power window switch until the
window is fully open and continue holding the switch down for approximately 5 seconds after
the window is completely open.
2. Pull the power window switch up until the window is fully closed and continue holding the switch
up for approximately 5 seconds after the window is completely closed.
3. The window should now be normalized and the window should perform the express up and express down
functions and should index normally when the door is opened and closed.
From 2016 Shop manual
Jim
2017 2SS M6 H50 Convertible 1 of 158
1100 8/05/16 | 2000 8/08/16
3000 8/10/16 | TPW 9/5/16 8/13/16
3100 8/26/16 | 3300 8/30/16
3400 8/31/16 | 3800 9/8/16 PS#2293
4B00 9/10/16 | 4200 9/13/16
5000 & 6000 9/14/16
jwober is offline   Reply With Quote
Old 12-18-2018, 04:06 PM   #8
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Battery only 1 year old...
Car struggled to start few days ago.
Now each time it starts I get msg to reindex driver window. (Fix it perfectly each time)
Needle on battery display is only between 11 & 12, think it used to be on 14?
Any ideas? Replace battery again?
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 06-03-2020, 03:19 AM   #9
Sunny91221
Drives: 2016 camaro 2 LT
@Adrian97c were you able to fix the issue?
am having the same issue. my battery died and since them driver side door was doing this and passenger side window was doing this intermittently.
Sunny91221 is offline   Reply With Quote
Old 06-16-2020, 11:23 AM   #10
StormBlaze
Drives: Hyundai Tiburon (Soon to be Camaro)
I'm also having the same issue, did you have any luck fixing it?
StormBlaze is offline   Reply With Quote
Old 06-16-2020, 01:13 PM   #11
Sunny91221
no did. both windows were having the issue and some times driver will work and sometime passenger window door. if i open any door. am starting the engine and do a reindex and then turn off the car.
Old 06-16-2020, 07:30 PM   #12
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
If you can't clear it, it's what I had. I'm on my 3rd window motor and I think I just lost another one.
TonyNo is offline   Reply With Quote
Old 06-16-2020, 07:43 PM   #13
Sunny91221
Replacing window motor fixed the issue for you?
Old 09-07-2020, 06:58 PM   #14
Russ.
Super Sport Track Pack
Drives: 2018 2SS 1LE, 2015 JKU
Is there a separate procedure for resetting/re-indexing the window if it will not go up all the way?
Went out to the garage today to get my glasses from the Camaro and all was fine. Went back a while later to return them and noticed that the driver side window was open about 2". At first I thought maybe the door wasn't fully closed but that is not the case. My next thought was that the unlock button on the remote had inadvertently been pressed and held causing the windows to open partially.
The auto down works on the window however the auto up does not work and when I hold the switch it goes up but stops a couple inches short of where it should be.
Wondering if I should try this procedure right away or if there is something different I could do first to get it to go up all the way.
Thanks
Russ.
Russ. is offline   Reply With Quote
