Old 03-20-2017, 11:21 AM   #1
TECHTURTLE
TECHTURTLE's Avatar
Harmonic balancer R&R tools
Hey guys, I'm getting ready to install my E-Force suppercharger and I'm looking for the proper balancer removal and installation tools. After searching I see a 3 claw should work for pulling but what about the install? Everything I look at doesn't match for a 2016 LT1.
Any information / suggestions would be appreciated.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 03-20-2017, 11:26 AM   #2
ProCharger
Drives: Many C7's
Should be able to rent the "Chrysler" style removing tool from your local AutoZone.
Or other auto parts store.
Makes life easy.
ProCharger is offline   Reply With Quote
Old 03-20-2017, 11:31 AM   #3
Omega
Drives: G8
I used this, I assume the bolt thread is the same for an LS
Look at this on eBay http://www.ebay.com/itm/231559264874
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-20-2017, 11:36 AM   #4
brettman
Drives: 2016 Camaro SS
The removal is easy (3 jaw) install is progressive (belt alinement)
brettman is offline   Reply With Quote
Old 03-20-2017, 11:55 AM   #5
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Pretty much what I used. Went to Fastenal and got a 3' length of threaded rod. Cut it off and put on 2 nuts. Probably $10, and I still have 2.5' of rod left.
00 Trans Ram is offline   Reply With Quote
Old 03-20-2017, 12:14 PM   #6
brettman
It's all good (hammer, pry bars..lol) the problem lays with tracking of the belt.
Tampered shaft, tighten TOO much, belt wear....Tracking is the key. Track over, or under...noise. spray don't fix it
Old 03-20-2017, 12:38 PM   #7
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Braking the bolt loose is going to be the biggest problem.
E-Ray is offline   Reply With Quote
Old 03-20-2017, 12:47 PM   #8
travislambert
Drives: '17 ZL1
This puller works awesome.
https://www.amazon.com/OTC-6667-Harm.../dp/B000P6UT2I
Breaking the bolt loose is the biggest problem. I used a large strap wrench to hold the pulley.
travislambert is offline   Reply With Quote
Old 03-20-2017, 02:36 PM   #9
80sMetalDude
80sMetalDude's Avatar
Drives: .
Thanks for this post so that OTC version worked fine???
80sMetalDude is offline   Reply With Quote
Old 03-20-2017, 02:50 PM   #10
travislambert
Drives: '17 ZL1
Yeah. I understand that some tools like this are junk, but this tool has decent quality and it has a low profile that makes it just perfect in tight spaces. You won't even need to pull the radiator or anything.
Oh. BTW the A/C belt can be a real pain to remove too without the proper tool. If you overstretch them, they're ruined. In my case I just bought a new one ~$15 so I could cut the old one off. The new belt can be easily installed with a heavy duty zip tie if you do it before fully installing the new pulley.
Old 03-20-2017, 03:27 PM   #11
ProCharger
Drives: Many C7's
You can rent that exact tool from most places.
Thats what I do.
But, the bolt will come right out with a little heat from a MAP gas torch.
Then just put the bar on it, and have your buddy hold the crank.
Shouldn't take to much force to remove it (with a breaker bar of course)
The little heat is the key.
Old 03-20-2017, 04:26 PM   #12
80sMetalDude
Drives: .
So is this the bolt in the instructions that in the install they say to torque to 230lbs? This guy isnt doing the install but I did read it!
Old 03-20-2017, 05:30 PM   #13
brettman
What the hell do you care, your not installing your's (twiddle thumb comp)..lol
Old 03-20-2017, 05:31 PM   #14
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
That ^^^^^ puller works, You can find it a lot cheaper on ebay I think I paid $35 shipped.
To remove the crank bolt heat it with a torch for about 20 seconds it will heat up the Loctite and come right off with little to no effort at all.
The Crank bolt is the same spec's used on LS motors so that ebay installer will work as well.
If you want to go ARP the P/N is 234-2504 it has to be torqued to 238 ftlbs but is reusable and you will need a 12point socket I think 1-1/16 is what I used.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
