03-18-2017, 08:51 PM | #1 |
Drives: 2016 2SS Join Date: Dec 2015
Automated brake bleed with ACDelco GDS 2?
Is anyone familiar with the automated brake bleed procedure in GDS 2? When I run it it doesn't seem to actually do anything. It just sits there saying "pending" and there is no indication of what to do next. Aside from the dash chiming and telling me that stabilitrack needs servicing, it doesn't seem to touch the ABS module. What am I missing?
05-08-2018, 09:52 PM | #2 |
Bump. It's been a year, but I'm still curious about this. Has anyone ran through this before?
05-09-2018, 02:08 PM | #3 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I actually just did this procedure last week successfully and there were obvious messages that came up telling you which corner to bleed. Unfortunately I'm relatively new to this system and haven't used it except for that one time bleeding, but I am wondering:
1) Is the vehicle "keyed" to the run state? Just pushing the button once without the clutch/brake puts the vehicle in accessory power mode, but pushing and holding sets it to run. Run will turn the full dash on and give full access to all of the driver display pages and all of the vehicle settings in the infotainment system, accessory with have some of them as not accessible or grayed out. 2) Are there any available updates to the diagnostics package or GDS software you can download/install? 3) Based on voltage, I'm assuming you're hooked up to a charger, right? 4) Have you tried any other functions through GDS to confirm it's not an issue with the software or the MDI?
2017 SS 1LE.
05-09-2018, 02:57 PM | #4 | |
I'm going to spend the $40 for the Vehicle Programming Software for the modules too. It's good for 24 months of ECU updates now, which it a much better deal that I remember it being before. Maybe there's an update for the ABS module itself that will make this work. |
05-11-2018, 08:44 AM | #5 | |
2017 SS 1LE.
05-11-2018, 10:02 AM | #6 |
Drives: 17 SS a8 Join Date: Feb 2010
I did this procedure but am not sure of the brand of diagnostic tool we were using. The car made a lot of noise and it told us what to do.
The part I was not clear on was it said hook up a gm brake bleed tool and then just pump the brakes every few seconds. My imagination tells me this tool has a one way valve that connects to where the caliper bleeder is and some method of recycling the fluid back to the master cylinder. Has anyone seem this tool? We followed the directions other than just bleeding the normal way. Bleeder closed, couple of pumps, hold it, bleeder open, pedal falls, close bleeder and start over.....
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
