Old 03-17-2017, 01:11 AM   #1
Daboom48
Drives: 32 Ford 55 Nomad 69 Ve 14 M5 17 ZL1
Alternate ZL1 Tire Sizes
Is there an alternate larger set of tires you can run that get some more rubber on the ground but don't compromise rubbing?
Daboom48 is offline   Reply With Quote
Old 03-17-2017, 08:24 AM   #2
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
I know there is a guy here that put 315s on his SS. LethalCamaro I think is the guy. He has videos on Youtube about it too.
KLR ZL1 is offline   Reply With Quote
Old 03-17-2017, 08:48 AM   #3
1967RS327
1967RS327's Avatar
Drives: 1967 RS 327 Muncie, 2017 ZL1 6spd
I'm think of 315's or 325's when I replace my rears. Idk what will fit yet..
1967RS327 is offline   Reply With Quote
Old 03-17-2017, 08:55 AM   #4
Jimmytt6
Jimmytt6's Avatar
Drives: Pontiac G8 GT, Camaro 94Z28,69 Z/28
The ZL1 1LE has 325s with 12" rims.. does anyone know if GM did some thing so
that size will fit? I assuming it will fit a regular ZL1 also with right offset.
1969 Camaro Z/28 sold
1994 Camaro Z/28 sold
2009 Pontiac G8 GT current toy
Jimmytt6 is offline   Reply With Quote
Old 03-17-2017, 09:10 AM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
You mean 19" rims?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 03-17-2017, 09:18 AM   #6
Yes they did... DSSV dampers are the difference that allows that width over the Mag Ride.
Old 03-17-2017, 09:28 AM   #7
Burnt Rubber
Burnt Rubber's Avatar
Drives: 1991 1LE & 2017 Red Hot ZL1
What is the largest drag radial we can fit on a regular 17 ZL1? And who has found what drag radial works best on this car?
Burnt Rubber is offline   Reply With Quote
Old 03-17-2017, 09:39 AM   #8
URBAN LEGEND
URBAN LEGEND's Avatar
The ZL1 1LE must have 11.5" or more rear wheel width for those 325s.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 03-17-2017, 09:41 AM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
They're 12", actually.
Old 03-17-2017, 09:42 AM   #10
URBAN LEGEND
Then on that car 335 is doable. But that's that car.
🔺22 RS E TRON GT
🔺21 Model S Plaid
Old 03-17-2017, 09:48 AM   #11
GatorsZL1
GatorsZL1's Avatar
Drives: 2017 BLK Camaro ZL1
idk, i'm running 12" rims just fine with no mods.
GatorsZL1 is offline   Reply With Quote
Old 03-17-2017, 10:03 AM   #12
Mr. Wyndham
The rear's might be ok. They did futz with the track width a bit on the ZL1 1LE, pulled it in, to adjust the turn in bias.
But up front - the DSSV coilover struts are significantly thinner to accommodate those wide front wheels/tires.
Old 03-17-2017, 10:31 AM   #13
GoneBoy
Drives: '17 ZL1
Waiting for my wheels to arrive now, and my plan was to fit some 295/30/20 mp4s on the 10" fronts if possible. Just eyeing the fender you would think you have some wiggle room to bring those front more flush with the body, but once you fully turn the stock wheels/tires, it's actually already pretty close to that back portion of the wheel well.
GoneBoy is offline   Reply With Quote
Old 03-17-2017, 11:30 AM   #14
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
that would most likely compromise handling running the stock rims anyway..
Evolvedx27 is offline   Reply With Quote
