![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
Drag pack/Racestars Question
I see Summit has a Racestar part #92-795252DP-30 this wheel is 17x9.5 with 6.43 back space compared to the #92-795252DP with 6.00 back space that I see most people are using, I also hear concerns of rubbing /sticking outside the wheelwell with the 6.00 bs. Has anyone used the wheel with the 6.43bs. Would this fit up inside the wheelwell better without any rubbing issues outter or inner? Tire will be a 28 inch MT,M&H drag radial or hooiser slick .Just prefer the tire tucked in .
Those wheels are based off my wheels and work for a lowered car which mine is. I knew they were going to change and yes it keeps the tire under the fender wells. Of course they'll work on lowered or non lowered and those are the ones you want.
Thanks for the info, I've read on one of your posts that you had custom back space .That's great Racestar are making them standard now. Good luck on your quest for 10.80s and hopefully even quicker.Looking forward to all your future build and drag strip details.
We will know tomorrow if the tires will hook close to 550rwhp and we they do I think 10's will happen. Temp are going to be in the upper 50's which will be real close to where it was last fall when I went 11.71 with 395 rwhp. Fingers crossed.
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I would just go with the same backspacing as the set I got for Zack:
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
If your going to lower it the 6.00 bs will rub, That's why Mike at Race Star did a one off for me and now that's the 6.43 which will work on manufactures set up and lowered. Personally I don't like tires that hang out from under fender wells. I'm a tucker.
#7 |
Drag pack ordered went with the 6.43bs I'm a tucker too! Also went with the M&H drag radials thought I'd give em a try rear wheels are supposed to be shipped the 5th and the front M&H will be a few days also. Hope to get a few passes in completely stock so I can compare.
#8 |
![]() Drives: 2020 Elkhart Lake Blue 1LT Z51 C8 Join Date: May 2009
I have 6" BS and it is lowered, but nowhere near as low as layinlo15. I have BMR suspension springs. It has been no issue in normal driving. Track time comes when it opens later this spring.
These are M&H front and back.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!! Sold 9/17/19 :( 2020 C8 ordered!! "The greatest sound in the world is a Rolls Royce Merlin over 100 inches" www.timadamsphotography.com |
#9 |
Yes Tim I got everything the same as you except I did the 6.43 bs incase I want to lower it a little more than yours.keep us updated on your ets drag pack vs stock tires if you get some passes in before I do
#10 |
I hope they don't hit. Here is another pic. I really don't want to have to buy another set. The stock springs will not be going back in to get it higher.
Stock the best I ran was 12.21. Never had the mineshaft air to run in.
#11 |
Looks great I just have no clue how much these cars squat on the launch are your new springs any softer ? I see some rubber build up there on the lower quarter looks like you've been trying em out
#12 |
I don't think they are any softer. I have a lot of BMR stuff installed. It's pretty stiff. The rubber is from running at the track on the stock tires.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Here is mine squatting at the track. Stock height.
#14 |
Pray are your front shocks stock? Awesome pictures
