Old 03-16-2017, 08:23 PM   #1
RobsCountach
Drives: '17 LT 2.0T AUTO
Shift Points on the 8-speed Auto
So, just picked up my 2017 2.0t with 18 miles...WooHoo. I've owned quite a few Camaro/TA in the past.
Once the 1.500 mile break-in passes, am thinking about the Injen EVO7300 intakes. One of its benefits is bringing peak power to 6k (not just the 5.6k) However, where does the car shift when you floor it ?
If the car shifts at 5,600 there's a loss of benefit there for me.
Thanks all !
RobsCountach is offline   Reply With Quote
Old 03-17-2017, 12:01 AM   #2
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
Thanks all !
I don't have an auto, but manual mode would be your best friend for that. The stock transmission tuning is quite conservative and shifts early from what I've seen.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 03-17-2017, 08:50 AM   #3
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Yeah the Auto will shift you very, VERY early if you are not putting your foot through the carpet. However! The transmission will shift around 6k rpm if you are really pushing it. I have left it in Auto mode and actually gotten nervous that it was not going to shift. So that will give you a good idea.
I literally never drive in Auto mode, always manual shifts for me. I like the control and I don't like being in 7th gear going 30 mph.
Plus... I like downshifting
EDIT: I have the Evo7300 and I love it. If you are looking for more blowoff noise, go with the open Injen CAI and not the 7300. Both look great and perform great.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 03-17-2017, 11:37 AM   #4
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
Thanks all !
Wide Open Throttle shifts will occur between 6200-6300RPM on the stock ECU tune. You will not lose anything gained from the intake. You've definitely picked the right intake! I've posted all over this site about how nice the Injen Evo 7300 is compared to the other options available.
I wouldn't consider 6200-6300RPM @ WOT to be an early shift. I'm assuming you're talking about part throttle shifting?
ChicagoTommy is offline   Reply With Quote
Old 03-17-2017, 02:07 PM   #5
b0bsaget007
From the videos I've see with the auto 2.0T, I've seen basically all the WOT upshifts at 5500-6000 RPM. Like I said, I don't own an auto, so I haven't experienced its behavior, and I'm only basing my information from what I have seen.
Old 03-17-2017, 02:44 PM   #6
ChicagoTommy
Tach lag is an actual thing. I'm basing my estimates off data logs.
Old 03-17-2017, 08:02 PM   #7
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Are you serious?! 30 mph in 7th gear? Does the engine seem like it's lugging?
I use to drive conservative with the manual until I learned that I can still get 27/28 mpg by staying in the power band around 3k rpms. I've got so used to it that I can't stand driving conservatively anymore because of the lag.
edgehead2000 is offline   Reply With Quote
Old 03-19-2017, 10:15 AM   #8
whiskeyfed
Pat
whiskeyfed's Avatar
Yeah it's a little lugging but im sure the engine is designed to run like that. I live in an area where if I get on the highway, there's a 90% chance of hitting awful traffic 24/7. The a8 was a no Brainer. That being said it's not bad, and 7th going 30 was a bit of an exaggeration but honestly going down my residential street at 25, it gets to 5th gear. I just cope with the auto by putting it in manual mode
Old 03-20-2017, 12:02 PM   #9
RobsCountach
Great Information !
Appreciate it ...
