Old 03-14-2017, 03:57 PM   #1
zadar1983
Drives: 2016 2LT RS Hyper Blue
e85
Can the v6 take E85? If so any idea what the gains are?
zadar1983 is offline   Reply With Quote
Old 03-14-2017, 04:14 PM   #2
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
You know you will need a e85 kit, dont put it in your car without it.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 03-14-2017, 11:04 PM   #3
willoverkill
willoverkill's Avatar
Drives: Fast
Not yet, working on a prototype kit. On an LFX 3.6, the gains with Overkill E85 tune over 93 octane tune are about 12-15 wheel horsepower, and the LGX should perform the same
willoverkill is offline   Reply With Quote
Old 03-26-2017, 06:36 AM   #4
lopezangel886
Drives: 2016 v6 camaro rs
Any updates on this flex fuel kit?
lopezangel886 is offline   Reply With Quote
Old 03-27-2017, 01:36 PM   #5
bdar66
Drives: 2016 camaro lt2 rs
i have ran e85 in many of my cars with out swapping any thing into the car. the only "kit" you are referring to is a flex fuel kit and thats so you can mix regular fuel and e85. if you want to run straight e85 and leave other fuel behind there is nothing else to swap. go get your car drained filled and tuned on a dyno.
bdar66 is offline   Reply With Quote
Old 03-27-2017, 02:21 PM   #6
KMPrenger
KMPrenger's Avatar
I believe the biggest differences I recall with the former V6 engines is that when tuned for E85 and ran with it, the TQ was a bigger improvement than peak HP.
Old 05-31-2018, 10:16 AM   #7
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
Seems like this thread got dormant for a year. i thought i'd wake it up, lol.
Anyone has any inputs regarding E85 and tune on our V6 ? i am considering it, but wanted to make sure the install for the E85 kits that have been mentioned before doesn't require getting under the rear of the car like the fuel pump and stuff. and any performance gains you guys seen on a dyno, or quarter mile?
I will appreciate anybody's recent experience with the E85 tune.
mano_camaro is offline   Reply With Quote
Old 05-31-2018, 11:12 AM   #8
Its_LouieV
Drives: 2016 Black 2LT/A8/RS/NPP
also interested in this. With 87 octane rising past 3 bux and E85 still at about 1.95 I'd like this even for the savings
Its_LouieV is offline   Reply With Quote
Old 05-31-2018, 11:18 AM   #9
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Your savings will be minimal, if you get any at all. E85 is used in greater amounts than E10 gasoline, so your mileage will drop significantly. Like, 20-30% lower. E85 is for power gains (and a "greener" fuel), with the best gains with boost.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 05-31-2018, 02:01 PM   #10
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Right now its all or nothing with E85 you can do a full E85 tune as no flex fuel options are available. And doesnt look like it will be an option.
I get about 350 miles mostly highway out of a full tank of E85 and usually got just short of 480-500 on a tank of 93.. So its a 30% loss in MPG but with E85 to premium price difference its actually cheaper to run E85 right now. I can get E85 for $2.15 Premium is pushing 3.50-3.60 sometimes more.
So more power cleaner running fuel engine LOVES it.. = to or less to run then 93 rightnow there is no downside other then availability.. but I have a few stations around me.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 05-31-2018, 05:18 PM   #11
Kenny Camaro
Drives: 2013 1LT RS Camaro
Drumbc did the Overkill tune and the 80mm/ Ported Intake Manifold combo on E-85 and it dynoed at 310 rwhp.
Kenny Camaro is offline   Reply With Quote
Old 05-31-2018, 10:34 PM   #12
mano_camaro
IYAOYAS
Cool, thanks all for your inputs. I guess if i end up going for E85 i should start first with a portable tank full of E85 so i can burn any remaining 87 octane while I pwn a "Rustang" on the way to the dyno tuning shop,
Old 06-01-2018, 06:57 PM   #13
Kenny Camaro
Overkill tune with the 80mm Throttlebody/Ported Intake Manifold combo on E-85 has dynoed at 310 rear wheel horsepower and is readily available!!
Old 06-02-2018, 04:15 PM   #14
jingaling
Drives: 2016 Camaro 1LT V6 MT
Just curious... What kind of gains can be expected with that setup on 91? I don't think I've seen that posted up yet. And have dyno sheets been posted up for the e85? Thanks for all the work you guys are putting in for these cars
jingaling is offline   Reply With Quote
