03-11-2017, 04:54 PM | #1 |
Drives: 2012 Camaro SS Convert Join Date: Feb 2017
Decided to change stock head unit
After thinking long and hard about it. I was going to go with the mylink set up in my 2012 but decided I would rather go with an aftermarket head unit from Ken wood. Since I would have much more features over the stock one. Costs wise it would be a little less as well.
My question is... I plan on ordering the PAC dash kit. I know it comes with pretty much all you need. But I recently bought the harness from sub thump to add a subwoofer to my BA equipped system. What I am trying to do is have the after market stereo with stock speakers and my amp in the trunk with my sub. Do I have to buy anything else or can I just unhook the rca cables from the stock amp in the trunk that's plugged into the harness I got from sub thump and then run it to the new Ken wood head unit? Sent from my iPhone using Tapatalk |
03-12-2017, 09:43 PM | #2 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Cannot run rear OEMs with an aftermarket amp
03-12-2017, 09:45 PM | #3 |
Amp or head unit?
03-14-2017, 09:16 AM | #4 |
H-Town Camaro Club
Amp, I misread your OP. If you're just swapping the HU to aftermarket, you should be fine.
03-14-2017, 09:26 AM | #5 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
ok, why can't i run my rear OEM Speakers with an aftermarket amp?
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
03-14-2017, 09:50 AM | #6 |
Drives: Black 2011 2SS/RS / Black 2013 ZL1 Join Date: Feb 2012
Sub thump sells a speaker harness that allows you to run your rear OEMs with an aftermarket amp.
Sent from my VS987 using Tapatalk |
03-14-2017, 05:25 PM | #7 |
Drives: 2011 2SS/RS Join Date: Feb 2016
03-14-2017, 08:12 PM | #8 |
Drives: 2015 Camaro LT Join Date: Sep 2016
The OEM rear speakers require a 4 channel amp by themselves, and likely a 2 channel active crossover as well.
03-14-2017, 08:16 PM | #9 |
You mean he can't amp the stock speakers cause they will burn out ?
03-14-2017, 08:44 PM | #10 |
03-14-2017, 09:03 PM | #11 |
Can you use the wires running to the speakers to use aftermarket speakers in their place when adding a 4 channel amp?
03-14-2017, 09:06 PM | #12 |
You can use a 6ch amp. 2 for fronts and 2 for rears crossed over as HIGH as possible on the amp usually 250hz. the 6x9 will take 40wRms MAX. i drove 100 to them and did las but they make a lot of noise if over 40wRms crossed over at 100hz ( 80hz for rap music ) Or a 4 and a 2ch. NOT MONO. must be a 2 channel.
03-14-2017, 09:08 PM | #13 |
Was thinking about just installing aftermarket speakers to replace all of them. Was thinking a nice 4 channel amp and just get rid of the stock amp completely. Is this hard? Would I have to run all new wires ?
I have a convertible Sent from my iPhone using Tapatalk |
03-14-2017, 10:02 PM | #14 | |
Verts use different setup. They have a actual sub. |
