![]() ![]() ![]() Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Steering Issue
I've had my car for about a month now with only 350 miles on the odometer and every once in awhile the steering seems to act like the power steering pump quits for a split second then return to normal. This only happens at low speed and seems to only happen turning left. I read a thread awhile back that said something about GM was aware and was working on a software fix for the issue. Does anyone have any new information on the subject?
I used to be Dragoneye...
It's worth being real careful to pay attention...is it a power steering issue? Or the big tires tracking on bumps in the road?
#3 | |
I'll try touring and see if their is a difference. |
Don't be hesitant to take it in for the dealer service guys to look at, either. If it is a steering gremlin, get it documented - it'll help you, Camaro Team, and the rest of us! |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I bet it's the same neg ground issue the 5th Gen's have....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
#6 | |
![]() Drives: Millennium Buzzard Join Date: Dec 2016
Order number: VBKP6D - Build date: 3/15
#7 |
Well that may be the case, however there are so many reports of different situations with these direct drive racks that there may also be some serious safety concerns.. Please see this......
http://www.camaro6.com/forums/showthread.php?t=485889
#8 | |
KaBoom1701
Mods:
#9 | |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
#10 |
#11 |
#12 | |
#13 |
#14 |
Different places each time, not something I can replicate, at least at this point I think so.
