Old 03-11-2017, 10:08 AM   #1
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
DIY manual trans fluid change for the SS?
I've been looking for the "how to" on this for some time. The search function seems permanently off-line.
Anyone have a link or able to post up a good idea?
Thanks!
Ventmaster is offline   Reply With Quote
Old 03-12-2017, 06:53 AM   #2
1LE caSSper
1LE caSSper's Avatar
Drives: White 1LE
There's two bolts easy to identify, one on top one near the bottom.
Unscrew the drain it will empty out. Tighten & torque & retorted it.
Undo the top fill plug & fill until the fluid level seeps out
1LE caSSper is offline   Reply With Quote
Old 03-12-2017, 08:52 AM   #3
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I did this recently. The very lower drain plug is in a hard to get to spot.. Like the Tranny rear cross member is right in the darn way. You'll see a little sensor screwed into the tranny very close to that area. Near the bottom. It is the Tranny Temp sensor. You can simply disconnect the electrical connector and unscrew the sensor and use this as a drain. I had the front of my car up on jack stands and this helped angle the car so the fluid would come out good. After the fluid seemed to stop I jacked up the rear and saw a little more drizzle out. After that put the sensor back in, plug it in and use the top Fill plug to replace fluid of your choice.
I went with Mobil 1 Synth and it made shifting noticeably smoother. If I had it to do all over again I'd probably go with Redline. I heard that one is very good as well.
Dysan911 is offline   Reply With Quote
Old 03-13-2017, 06:54 AM   #4
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
A quick tip, always loosen the fill bolt first.
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
Old 03-13-2017, 12:40 PM   #5
Ventmaster
Ventmaster's Avatar
Thank you gentlemen!
It sounds straight forward. I was concerned the trans cooler on the SS might present something unusual.
I will be sure to measure what drains out and put at least that much back in. I didn't know if it was possible to drain the cooler (a little radiator I guess?) and then need a special sequence in order to re-fill it completely or release any trapped air.
Thanks again.
And BTW- I'll be using Royal Purple Synchromax because of past positive results I've had with that brand.
Old 03-13-2017, 03:21 PM   #6
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
I did mine very recently - Used the Redline D4 ATF - Much better than stock - and IMO better than my past experience with Royal Purple. I ended up removing the transmission brace as I was worried about making a big mess.
Somewhatdamaged
somewhatdamaged is offline   Reply With Quote
Old 03-13-2017, 04:06 PM   #7
Ventmaster
Ventmaster's Avatar
Somewhatdamaged
Removing the brace long enuff to drain was exactly what I was considering- did you place anything under the tranny (bottle jack with a block of wood or a box) to support things while the brace was off?
Also, I've already bought the RP, so I'm stuck with it but will report back here about results. If I'm disappointed, I'll change it again, LOL. After putting up with the clunker trans in my last 5th gen V6, I'm not gonna quit til this one's as good as it can get either!
I was really impressed with this trans for the first couple of thousand miles but when the weather got cooler (I mean the 50's) it got balky and could have gotten "crunchy" if I had forced shifts. I want that butter feeling back!
Thanks again!
Old 03-13-2017, 10:19 PM   #8
somewhatdamaged
Drives: 16' 2SS M6
Thanks again!
I was fortunate to have access to a lift to do the job. I did use a trans jack to hold it up. I also removed a small "brace under the brace" as well to have a clear, unobstructed path of the drain plug. Be careful as there is this kind of sharp plate of thin metal underneath those braces and you can cut your fingers on it. Also, the tranny fluid shoots out of that drain hole, so have your drain pan ready to go. I used pretty close to the whole four quarts on the refill, using a Harbor Frieght transfer pump.
Old 03-17-2017, 11:21 AM   #9
Ventmaster
Ventmaster's Avatar
Good info- thank you very much!
Old 05-14-2018, 12:14 PM   #10
6spdhyperblue
Drives: 2SS 1LE
Thanks again!
Here’s a little tip I learned. If you want to improve shift feel, bleed the brakes more frequently.
Old 05-14-2018, 12:59 PM   #11
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
https://www.camaro6.com/forums/showthread.php?t=492814
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
