Already Pro-Charged guys
I have read countless information on this forum, on websites, and spoke with a few garages about centri vs PD. My question is for the guys running a pro-charger. What is the extra maintenance like on these, Do you have traction issues on the big end with street tires, and do the chargers need rebuilt every 50k? I'm really curious if anyone is running street tires and using this just for DD and not track time.. how does it drive and fit the DD aspect. What's the fuel usage like and is it usable street power.
I'm leaning towards doing a pro charger over a Whipple or Maggie and the questions above are my concerns on the pro chargers. I like not worrying about heat soak, IAT's, and too much torque on the bottom end. I love the maintenance free aspect of the PD set ups and the torque. After all, torque is how hard you hit the wall haha |
![]() Drives: 2016 1SS 6speed Join Date: Mar 2016
I've been dailying mine as of recent. First and second gear over 3K are pretty useless in my M6 due to tire spin. My mileage isn't that bad considering I drive like a jerk and like to listen to the blower whine. ProCharger included enough oil to do a few oil changes with the kit so that saves some expense.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
#3 | |
In five or six months I put 14k miles on.. is the added maintenance going to cripple me with oil changes and all? I also hear after 50k miles the unit needs rebuilt. I worry about the reliability, the maintenance, and traction lol
i drive my car as a daily also and have no probelms at all and none with tractaion, the procharger oil you can change every 10K miles i heard so thats not bad...and 50k i never heard to rebuild the procharger...
The 50k rebuild is my biggest hang up, that and no traction in the lower gears.. spinning won't get me anywhere lol. So I'm relieved to see that a rebuild may not be true! Have you had a PD style blower in the past by any chance?
Even ProCharger doesn't say anything about a rebuild at 50K. The oil is $40 for a 3pk from Summit. It's 1 bottle per oil change. It's really not that bad. I plan on changing the oil when I do the engine oil change. Easier to remember.
#7 |
yes my 5th gen had a pd blower and that thing spun like crazy until i got street slicks.. love the procharger cause it dont spin unless u really gun it in first cause of where the boost comes in on these in mid to hi range,, the highway pulls are fun.. things a beast and pulls hard up top... im pretty sure you change the oil every 10k my builder told me...
#8 | |
#9 |
So it sounds like I don't need to worry about the rebuild then, and the oil change is no big deal. Thanks for the input, I'm feeling much better about going pro-charger. Do you think the hwy miles I put on will be an issue with one?
#10 |
I don't think you'll have any issues. I've known guys that DD ProChargers with no issues. If you wait until the middle of June, I'll let you know how it survives the Power Tour. That's a pretty good test if you ask me.
#11 |
That will certainly tell the reliability, but I want to get my car finished before this driving season gets here lol. I'm leaning heavily towards the pro-charger
#12 |
Twin Turbo
Drives: 2016 2SS Join Date: Jul 2016
You will be fine. Like mentioned earlier you drive normal it will be like street driving any car. The more throttle you add the greater chance you have of wheel spin because your building boost.
I had a 900whp 4th gen SS with a F-1 could drive it anywhere like a normal person in any weather with no problems. Heres a simple way to look at it. Throttle x Engine Load + RPM = Boost + Wheel Spin.
#13 | |
#14 | |
Twin Turbo
You won't have to worry about a downshift with throttle input unless you want it. Now I do not have a procharged 6th gen, I am actually working on a Maggie install on mine so I am only speaking of my experience with my 4th gen which was a manual. Adding the power for me changed how I used the car for example if your cruising along @ 70 in 6th gear and you need to pass someone moving slower there won't be a need to downshift because your car will have enough power. I loved I never needed to downshift on the highway, Your 5th gear with the procharger will feel like your 4th gear at stock power levels while cruising, 4th gear will feel like 3rd gear and so on.. So you shouldn't have any problems being able to determine how much power you need preparing yourself to go around someone. I will admit my TCS saved my ass a few times because I laid into the throttle too much just messing around on the street but that was usually in 1st & 2nd gear once you get adjusted to the new power levels of your car you will be able to determine when you need to use WOT vs 50% to get out in traffic or around someone. If your the type to go WOT every chance you get then your going to have problems but if your RESPONSIBLE and RESPECT the power levels you have you will be fine.
