Old 03-09-2017, 01:48 PM   #1
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
Blowout No Spare SMH!
I think I ran over a chunk of metal or something....
I was driving along minding my own business and heard a loud pop. As soon as I went to check the pressure on the display I got a warning (and an email) for no pressure on that tire.
70 miles from home, in the middle of nowhere, with no spare just fix o flat, which wouldn't have fixed that hole...
I had to get towed back.
Tire is unrepairable and they recommended changing both back tires to prevent damage to the differential from tire wear offset.
171LE is offline   Reply With Quote
Old 03-09-2017, 01:50 PM   #2
suzook
Drives: camaro
You could have drove the 70 miles. They are called RUN FLATS for a reason. And don't change both. That explanation they gave you, is the stupidest thing I have ever heard.
Hyperblue/JetBlack
Old 03-09-2017, 01:50 PM   #3
Vintage
Drives: 2017 SS 1LE
Glad you are okay and the car appears undamaged.
Vintage is offline   Reply With Quote
Old 03-09-2017, 01:53 PM   #4
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
The tires on the 1LEs are not run flats.
IG: @NC_M1SS1LE
Old 03-09-2017, 01:56 PM   #5
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
I'm tempted to throw a full size spare in my trunk for long road trips for this reason. I've been lucky to never have to deal with a flat yet, but it can happen any time, anywhere.
SPARTAN sui is offline   Reply With Quote
Old 03-09-2017, 02:17 PM   #6
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
1- SS 1LE's don't have run flats.
2- SS 1LE's have an eLSD and once a certain amount of wear is on a tire it is recommended to replace both. This actually is quite common on performance cars.
Old 03-09-2017, 02:24 PM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
First mod on my car was to throw a pinch weld jack, lug wrench, and spare (that clears both front / rear calipers) in the back. The 285 front fits in the trunk without issue. The 305 rear does if you take the four 15mm nuts off the trunk latch trim and take a Torx bit (can't remember size) and pull the two nuts holding the foam that holds the air pump out.
Once all that is out (plus the trunk floor cover), the 305 fits in there by putting it down in the well then pulling it up - allowing it to be snaked in there. Yes, the trunklid will then close with either front or rear wheel / tire in there.
If you don't want to go through that, the 305 can be put in a large trash bag and thrown in the RF seat when it is all the way back. Verified that, too. No way to get it in the back seat without removing the front seat first. Not enough room to snake past the seat and the B-pillar.
If you don't want to carry a full sized spare, you can buy or make an adapter like the V2 CTS-V and other guys use along with a spare like off a V2 CTS (V's did not have one). Need a taller spare tire though.
RUQWIKR is offline   Reply With Quote
Old 03-09-2017, 02:26 PM   #8
suzook
Drives: camaro
Well, what an idiot I am. So no runflats....AND no jack/spare? WTF?
Hyperblue/JetBlack
Old 03-09-2017, 02:28 PM   #9
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
that's what im alwaus scared about :( .. glad cars okay
cmeJATT is offline   Reply With Quote
Old 03-09-2017, 02:29 PM   #10
Casalino
Casalino's Avatar
Drives: 17' 1LE BLK
^^^^^ LOL "could have drove the 70 miles" "they're run flats"
Go home your drunk
Casalino is offline   Reply With Quote
Old 03-09-2017, 02:56 PM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
1LE gets extreme summer non-runflat tires, an inflator kit in the trunk, and 3 or 5 years of roadside assistance, depending on what broke.
For sure a more thorough fix-a-flat tool kit and/or a AAA Diamond Elite® card wouldn't hurt.
Old 03-09-2017, 03:16 PM   #12
TJay74
Also with tire sizes being different from front to rear on the 1LE if you are going to carry a spare it would need to be the rear otherwise if you ran a front on the rear you could potentially destroy the rear diff in a short amount of time due to tire height differences.
Only bad is a rear spare tire setup in the OEM size wont fit on the front of the car. Now, you could go with a narrower tire that still maybe meets the overall tire height and will still fit on the front, but that will take some work as well as the aspect ratio will be lower than the already low 30 that the rear tires comes with.
Old 03-09-2017, 03:28 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i drove to vegas in my 1ss over the weekend which is about 4 hour drive and worried about the same thing! bought some fix a flat but yea if that happens your SOL sorry man!
Old 03-09-2017, 03:42 PM   #14
suzook
Drives: camaro
Go home your drunk
Look up a few posts dbag. I didnt know 1le's did not come with runflats. I have driven over 100 miles on a runflat with no issues.
Hyperblue/JetBlack
