![]() ![]() Drives: 2016 Corvette Z06 M6 Join Date: May 2009
Adding LT4 Fuel system to my Magnuson?
I currently run a Magnuson with a Rotofab on the supplied tune from Magnuson. Ive been thinking about adding the LT4 HPFP and Injectors, swapping the pulley and getting it retuned. Is this the best way to go about this? Can I expect 600-620rwhp?
If I add those fuel system parts, will I be able to drive it to my tuner at low rpm/speed?
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
I look forward to the response to this thread as well. My local shop told me how to get to 600-650 to the wheels safely with a Whipple install and it would be a cam with 32% fuel lobe and lash cap because of the fuel wall on the LT1. When I mentioned the LT4 conversion they told me you can't forget the LPFP in the tank because doing just the HPFP and Injectors were only part of the problem and leaving out the LPFP would still limit your fuel.
(edited)I did see where someone replaced the LPFP with the LT4 one and they cut a hole behind the rear seat to gain access to it. Also a gentleman that goes by Lethal Camaro is in the process of trying out a new fuel system that is being built for the Gen 6. Just youtube Lethal Camaro for his videos if you haven't already seen them. |
Totally forgot to mention that I am going meth initially to get me past the fuel wall.
![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
![]() Drives: . Join Date: Jan 2017
deleted stupid comment.
#7 |
I've read in the forums when doing an install of the Maggie style S/C to add the LT4 HPFP since it sits in that area. You have to remove the Maggie to get to the pump if you do it later. Without the low side, what are you really gaining by adding just part of this fuel system anyway? How are these chargers working on 16's without any fuel upgrades?
#8 |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Can only speak from my personal experience.
2016 Camaro SS A8, mods are Maggie, Rotofab, Borla Cat Back.
And that's where I left it last Saturday, didn't have the right size belt to go with a smaller pulley, so picked one up in Sunday and will be looking for more power later this week. It also might be time to consider adding some more exhaust components. I'm not looking to lose the stock cats, but I may add the shorty headers I bought a couple months back to see if they have any benefit. Last edited by toohighpsi; 03-08-2017 at 10:14 PM. |
#9 | |
Dyno Show Queen LOL
No E85 experience? Would like to do the same thing on E85 minus the meth hassle and worries!
#10 | |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
Subscribed ! |
#11 | |
#12 |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
I went with lt4 in tank pump, lt4 injectors, and lt4 hpfp on my build (which is still underway). Mine will be somewhere between 710-750 to the ground so until it's completed (one day) I won't really know. I can say though that on 93 pump I'm going to be tapped out. I don't want to run E, or meth although I know it opens up more advantages. I am going with a 93 tune bc I drive my car cross country and it is my dd and I don't want the hassle of looking for E or running out of meth.
#13 | |
http://www.chevyhardcore.com/tech-st...g-tube-headers |
#14 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
so to further digress on the identical subject, if I added a rotofab (advise on ether wet or dry) with the stock tune from Maggie, what type of HP should I end up with? and what HP rating are you guys ending up with, with the standard Maggie w/Maggie tune/intercooler kits. I apologies if this would consider a thread jack, but maybe to further digress on the above questions.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
