Old 03-07-2017, 08:53 AM   #1
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
M6 hard starting
Has anyone else experienced the starter spinning for several seconds before the car will start? Is this common? Rarely does the car ever fire right up. Almost thought it was out of gas and then VROOM!!!
snackbar64 is offline   Reply With Quote
Old 03-07-2017, 09:03 AM   #2
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
Is this the first Direct injection car you have owned? DI cars are slower starting due to the priming process of the fuel system.
mkorgan is offline   Reply With Quote
Old 03-07-2017, 09:12 AM   #3
snackbar64
snackbar64's Avatar
My 2013 fired right up. But I guess it's normal for this car.
Old 03-07-2017, 09:12 AM   #4
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Not abnormal. My guess; it's a symptom of the push button start. The starter spins before the fuel pressure is up. With a key, the pump starts a split second before the starter engages, allowing fuel to pressurize the rails.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 03-07-2017, 09:17 AM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
The long crank times has nothing to do with DI or push-button in general, otherwise every other DI and push button on the market would have the same "issue".
My hunch is it's priming the oil system prior to actually going into the crank fueling state. The crank times appear to be coolant and/or oil temp related. A warm LT1/LT4 engine fires much quicker than a cold one, and that's all in the calibration.
Until I do a datalog to prove or disprove this theory. You can rest assured however it's not a rule of thumb issue for DI or push button. This is a very intentional calibration by GM.
Old 03-07-2017, 09:28 AM   #6
thompstl1
thompstl1's Avatar
Drives: 2017 A10 ZL1
Are you pressing on the accelerator during start-up? My 1LE (for example) won’t start at all under full throttle during cranking (part of the design).Pressing on the throttle (even a little) made it slow to start also.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
thompstl1 is offline   Reply With Quote
Old 03-07-2017, 09:32 AM   #7
NB2017ZL1
NB2017ZL1's Avatar
Drives: 2017 ZL1 10 Speed Hyper Blue
Sounds perfectly normal
2017 ZL1
NB2017ZL1 is offline   Reply With Quote
Old 03-07-2017, 09:33 AM   #8
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
WOT during crank = flood clear = no injector pulsewidth.
You're not helping anything by having your foot on the pedal during cranking. It's not a carburetor, or even cable throttle. The ECU's got it handled.
Old 03-07-2017, 09:34 AM   #9
Listen to this start up. Not me in the car and I haven't experienced it since, but will check back in if I do.
I haven't started it very many times either
Old 03-07-2017, 09:39 AM   #10
snackbar64
snackbar64's Avatar
Yep that's it only mine goes a second or two longer before starting. Beautiful car. How many cartwheels have you done so far
Old 03-07-2017, 09:47 AM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
My 5th gen starts immediately, always has. I don't touch the gas.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 03-07-2017, 09:48 AM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Different engine, different calibration.
Old 03-07-2017, 09:53 AM   #13
Sven59
HAMMER PILOT
Sven59's Avatar
Thanks
Old 03-07-2017, 10:10 AM   #14
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
This sounds like a typical LT1/LT4 cold start to me.
Car looks amazing by the way, congrats!
