Old 03-05-2017, 11:17 AM   #1
Izzidigitz
Drives: Camaro
Noise from back window convertible
My convertible is making a weird popping noise that's coming from the back window. I've looked everywhere and have taken it in 4 times with no luck so far. Nothing is loose and the noise isn't necessarily a "rattle" but it drives me CRAZY. I absolutely love the car but I must figure out what this is and how to stop it. 2016 RS, and it's clearly coming from the back window since I can drive slowly and as soon as it raises to lower the top the noise stops. Any suggestions? Thanks!
Izzidigitz is offline   Reply With Quote
Old 03-05-2017, 11:49 AM   #2
Donner
Drives: 2017 50th SS convertible
Check your trunk; that handle may be rolling around (under the floor cover)...
Donner is offline   Reply With Quote
Old 03-05-2017, 12:38 PM   #3
Izzidigitz
Drives: Camaro
Definitely not that. I removed all of the floor covers in the trunk and looked. Then I literally got in the trunk and had my husband drive around the block to try to find it. You can hear it from the outside of the car too.
Old 03-06-2017, 01:16 PM   #4
FdeleonZ28
Drives: 2016 camaro ss convertible
same issue here it was faint at 1st,it got worse now.. its on uneven roads and small bumps when its more clear.. sound like something is loose.
FdeleonZ28 is offline   Reply With Quote
Old 03-06-2017, 01:29 PM   #5
FdeleonZ28
this might be our issue here izzidigits
http://www.camaro6.com/forums/showthread.php?t=477795
Old 03-07-2017, 08:23 PM   #6
Izzidigitz
Drives: Camaro
Thanks for the suggestions. Dealer has had it for two days and says they may have to replace the top. I'll update when I get more details.
Old 03-08-2017, 01:01 AM   #7
Biggdummy
Biggdummy's Avatar
Drives: 2016 camaro 2ss vert
Try pushing down on rear window to see if you can make the noise you hear while driving,if so it may be the back piece of trunk behind rear seat.I. stopped a noise by putting a square piece of carpet padding in between.You can pull up the bottom of the trunk panel enough to slide the pad in.
Biggdummy is offline   Reply With Quote
Old 04-22-2017, 12:37 AM   #8
Diggitydog
Drives: 2017 ZL1 Nightfall Convertible M6
Anybody have issue with wind noise at the driver door seal that joins the smaller back side window?
Diggitydog is offline   Reply With Quote
Old 04-22-2017, 07:39 AM   #9
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
Yep - several us here in fact. Ironically - after almost 900 miles now, mine is much better, but still there. Figure I'll bring it in eventually.
toro1966 is offline   Reply With Quote
Old 04-22-2017, 07:42 AM   #10
toro1966
toro1966's Avatar
There was a similar post sometime ago and it turned out to be loose tonneau I believe. He put some felt on it and it fixed the problem. I apologize for not being more specific, I'll see if I can find it for you.
Here you go found it. Not saying this is it, but might be worth a shot.
http://www.camaro6.com/forums/showth...=478741&page=2
loose, popping, rattle
