![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
Procharger VS stock driveline
Seriously considering a P1SC and just curious how the stock M6 driveline handles the added power?
2018 ZL1…Many mods to come
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
There should be no problem at all, if you stay at the base 7 psi.
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Depends greatly on how you will use the car in my opinion.
If you are just street driving on the stock tires, it might be ok. In other words, might not be able to hook up well enough to break anything. However, if you drag launch it with better tires mounted, I'd worry. Even stock motors with M6 have been breaking axles in that scenario. I do think the Procharger will be a little kinder to the parts on launch due to it's powerband, compared to a roots blower or nitrous. |
#4 | |
![]() Drives: 2016 1SS 6speed Join Date: Mar 2016
If this is your intended use and you can stick to it, you'll be fine. Just don't putnslicks on the car.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
#7 |
Drives: Many C7's Join Date: Apr 2014
#8 |
![]() Drives: 2016 Camaro SS M6 w/ NPP Join Date: Jun 2016
Once upon a time, I was gonna stay at the base boost level
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system, Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion 28"x10.5" MT ET Drag 28"x4.5" M&H fronts PB: 9.569 @ 151.05 |
#9 |
#10 |
exactly. I am looking into your new intake... goertz intake now... then drop in pistons and rods.. and max out this lil d1
#11 |
Girly you are out of control. Ha
#12 |
