Old 03-02-2017, 02:01 PM   #1
FdeleonZ28
Drives: 2016 camaro ss convertible
Colder spark plug
What spark plugs do these cars need for 1 step colder ? gonna run nitrous
FdeleonZ28 is offline   Reply With Quote
Old 03-02-2017, 06:45 PM   #2
SSFanboy
SSFanboy's Avatar
Drives: 2016 Camaro A8 2SS w/Maggie
You'll want to go with the Iridium NGK LTR7IX-11 (stock #6510) plugs. They're on Amazon, but you can find them a bit cheaper at Rock Auto:
https://www.rockauto.com/en/moreinfo...=1063036&jsn=1
In the interest of full disclosure, opinions will vary, and you may want to gap them at .035" to cut down on misfires:
http://www.camaro6.com/forums/showth...hlight=Iridium
Last edited by SSFanboy; 03-02-2017 at 07:40 PM. Reason: Correcting gap measurements
SSFanboy is offline   Reply With Quote
Old 03-03-2017, 05:10 PM   #3
FdeleonZ28
ive installed these plugs but am getting random misfires on cold starts,, seems to disappear when it heats up, iv gapped the plug at .35.. should I try gapping at .30 to attempt to eliminate the misfires?
Old 03-03-2017, 05:24 PM   #4
parish8
Drives: 17 SS a8
does it set a code? both stock gen6 Camaros I have been in seem like they have a random miss when cold. If there isn't a code I think it is normal.
Old 03-03-2017, 05:27 PM   #5
FdeleonZ28
it does not set a code but after cold soaked it stumbles at low rpm normal driving.. is that normal with these plugs?
Old 03-03-2017, 10:35 PM   #6
SSFanboy
SSFanboy's Avatar
FYI. I'm seeing a lot of resources that recommend closing the gap to .030 to help smooth out rough idles. I think that's worth a try. .030 is definitely recommended for a forced induction setup like mine, and I'll be installing these plugs with a .030 gap tomorrow.
http://www.morepowertuning.com/NGK-6510-8x
"Out of the Box Gap: .044 (1.1mm) (Recommended gap .028 to .032 for Forced Induction)"
Old 03-04-2017, 04:20 PM   #7
SSFanboy
SSFanboy's Avatar
Just got the car back. The idle is very smooth from a cold start, and I did some spirited driving. No issues at all with the .03 gap.
Old 03-04-2017, 05:55 PM   #8
hogwild87
hogwild87's Avatar
Drives: 2016 2SS Camaro
I'm running the brisk racing rr12's and I've had no issues
hogwild87 is offline   Reply With Quote
Old 03-04-2017, 06:04 PM   #9
Hyper SS
Hyper SS's Avatar
Drives: 16 Camaro 2SS
Installing with Procharger.
Hyper SS is offline   Reply With Quote
Old 03-06-2017, 12:11 PM   #10
FdeleonZ28
ok I regapped them to .032.. ill give .030 a try hopefully that works..
Old 03-06-2017, 12:15 PM   #11
JANNETTYRACING
JANNETTYRACING's Avatar
Open the gap to 0.042 and the misfires will go away.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-08-2017, 04:27 PM   #12
FdeleonZ28
that's safe for a nitrous set up?
Old 03-09-2017, 08:16 AM   #13
JANNETTYRACING
If your tune up is right it will be no problem at this power level.
Old 03-09-2017, 11:34 AM   #14
FdeleonZ28
STOCK TUNE
