Old 02-27-2017, 11:22 PM   #1
formoutofchaos
Drives: Camaro 2017 1LE
why not pro charge?
so dealing with my interior damage my car seems to me to be a track beast at this point the engine has been supercharged successfully in the c7 for years instead of worrying about perfect interior and such why not just super charge it and let it be a track car??? with moderate gains like 580 hp i always feel this car could have a ton more HP? it can handle it how risky is it to get a tune and CAI and pro charger with moderate gains
formoutofchaos is offline   Reply With Quote
Old 02-28-2017, 12:06 AM   #2
pullthatwigback
Drives: brz...
You mean a zl1?
pullthatwigback is offline   Reply With Quote
Old 02-28-2017, 12:10 AM   #3
MatthewAMEL
MatthewAMEL's Avatar
Weight. ProCharger will add about 120lbs to the nose.
When my warranty is gone, I'm going intake/heads/cam/headers. Add 100whp and 0 extra lbs.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 02-28-2017, 12:16 AM   #4
formoutofchaos
that little spool weighs a 100 1bs?
Old 02-28-2017, 12:17 AM   #5
formoutofchaos
Originally Posted by pullthatwigback View Post
You mean a zl1?
20k extra
Old 02-28-2017, 12:58 AM   #6
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by formoutofchaos View Post
20k extra
I've seen a new ZL1 for sale as low as $54k and some change so it's more like $14-15k price difference. More expensive cars get better discounts since not so many people truly want or can handle that kind of power also the Corvette prices are also another determining factor since there are cross shoppers .All things considered it makes more sense to me than adding a FI on a motor that is not initially designed for it. (heat was even an issue with a small BRZ engine when I added even the coolest running SC option -Rotrex centrifugal type) Heat would be even more problematic with a V8 so no wonder Camaro team needed 11 heat exchangers to keep the temps in check.
glamcem is offline   Reply With Quote
Old 02-28-2017, 01:00 AM   #7
HyperBlue
HyperBlue's Avatar
Drives: 2011 MB E350 wagon
I missed it. What happened to your interior?
2015 BMW M235i (sold!)
Old 02-28-2017, 01:33 AM   #8
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
I think it's 70-80lbs?
Anyhow 120lbs for 150hp is great, car isn't a featherweight you wouldn't notice it. Buy a light weight battery to offset it.
thescreensavers is offline   Reply With Quote
Old 02-28-2017, 08:57 AM   #9
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Why do so many people automatically jump to "more power" when they think of track cars?
seanblurr is offline   Reply With Quote
Old 02-28-2017, 09:01 AM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Adding weight to the nose, and reducing weight in the back (battery) is a great way to negatively alter the weight balance...you would notice that, especially at the limit.
Someone mentioned cam/headers earlier. One of the great characteristics of the SS 1LE is that it has a naturally-aspirated engine; don't screw with that! ...If I had a 1LE, that's what I'd do (again).
Old 02-28-2017, 10:47 AM   #11
formoutofchaos
Going to be a gigantic lawsuit :(
Old 02-28-2017, 10:48 AM   #12
formoutofchaos
Look under my car is cursed post , a detailing shop ruined everything by giving me a free interior coating to make up for bad exterior that had to be redone , it has changed the color of everything and left residue smears and it can't be taken
Off ;(
Old 02-28-2017, 10:59 AM   #13
formoutofchaos
Good points , add tax and it becomes 2ok
Old 02-28-2017, 11:31 AM   #14
67Builder
White knuckled & smiling
67Builder's Avatar
Drives: '17 ZL1 AKA Perfection!
Why add the weight, heat, complications?
If anything, since you're going to void your warranty anyway. Send your car to Katech and go with a stage 2 setup for around 9 grand.
600 HP naturally aspirated and no added weight. Plus you at least get a warranty from them for a year.
Of course if you do this. Don't forget you're going to (probably) have to upgrade some other components. But you'd have to do this if you go pro charger, katech, turbo...
Good luck with the interior hassles man!
2017 ZL1 A10 CFHood PDR NAV NFG - Order # VCSDRJ
TPW -
3/6/2017 VIN - 1G1FK1R62H0192950
6000 - 04/05/2017 - Delivered!
67Builder is offline   Reply With Quote
