Old 02-22-2017, 09:43 PM   #1
dmau9600
Drives: 2017 SS 1LE
Anyone drive their 1LE year-round in snowy states?
Considering picking up a 1LE, but do not have room for three cars. I live in MN, where we get plenty of snow and harsh winters. So, the 1LE would be driven year-round when necessary.
Proper winter wheel/tire setup is a given, I am just curious how others have fared with this car in the winter (ground clearance, availability of winter wheels/tires, etc...)?
dmau9600 is offline   Reply With Quote
Old 02-23-2017, 07:39 AM   #2
thewurzernator
Drives: 2022 2SS 1LE RAPID BLUE
drove mine this winter in Chicago, no issues, mounted 5th gen steel wheels and goodyear snows...
thewurzernator is offline   Reply With Quote
Old 02-23-2017, 08:19 AM   #3
Rich S
Drives: corvette
I am in Wisconsin, no chance this car would make it in winter here. Just way to low. If you are always on plowed streets then no problem but I do country driving with snow drifts. They would destroy the front end
Rich S is offline   Reply With Quote
Old 02-23-2017, 08:48 AM   #4
TJay74
You sure this is a 1LE, the 1LE has 6 piston red calipers that are considerably larger than the standard 4 piston Brembo caliper the SS uses. That is going to limit the wheel selection some as to what you can run.
Old 02-23-2017, 08:51 AM   #5
dmau9600
Drives: 2017 SS 1LE
I live in the city, and we have the wife's X3 for the bad stuff. Just need to be able to get around town when needed. I currently drive a GTI and previously had an M3 with winters, so I can't imagine the 1LE would be much different.
Old 02-23-2017, 09:14 AM   #6
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
He's got a v6 1le. Smaller brakes than the SS 1le
02fbody35th is offline   Reply With Quote
Old 02-23-2017, 09:29 AM   #7
thewurzernator
mine is a V6 1LE
Old 02-23-2017, 05:17 PM   #8
FlashBang23
FlashBang23's Avatar
Drives: 2017 1LE
Daily drive mine in Michigan, and have driven my last two 5.0s year round as well. I went out and purchased a new smaller set of 19" wheels for a winter setup and re-used a basically new set of winter tires from my Mustang (245/45/19) Sticking with that size my speedo is barely off and have had zero issue with driving in the cold/snow. All of that being said, I live in a very urban area and never have to deal with significant amounts of snow (had it out in 4-5 inches this year max). I could see clearance being an issue if you're in an area that doesnt get plowed quickly. For availability of winter setups, there are several wheels that will fit (just be careful of them fitting over the brakes) as well as tires. I went with some dunlops and they are awesome. I have blizzaks on my wife's Charger RT and honestly cant tell the difference. As far as the wheels are concerned, I am pretty sure we share the same bolt pattern as BMWs so there are several options....I got lucky and picked up a set of TSW Nurburgering wheels that were originally intended for a BMW.....guy backed out on them so I got like 30% off. My second option was buying a used set of 5th gen camaro ss wheels and winter tires. Locally several sets were available. I would think finding a setup that works would be super easy.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
FlashBang23 is offline   Reply With Quote
Old 02-23-2017, 09:15 PM   #9
Sleeks
Drives: None
I daily my 1Le. Using Michelin pilot alpin tires. Slightly narrower than stock.
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 02-23-2017, 09:16 PM   #10
Sleeks
Drives: None
-Brian
Old 02-23-2017, 10:08 PM   #11
kparker
kparker's Avatar
Drives: 2017 SS 1LE Artic Blue
Should have my 1LE SS in a couple of weeks and I already have the winter tires/wheels ordered and ready to put on. I wouldn't drive in deep snow but plowed roads should be fine here in Michigan. I purchased wheels with 20 mm offset so they should clear the brakes. If we ever get Winter here I'll let you know how it handles.
SS 1LE PDR Artic Blue (VBWZZJ )
ordered - 1/17/2017
1100 - 1/27/2017
3100 - 2/06/2017 TPW 2/27
3400 - 2/21/2017 TPW 2/27
4200 - 2/28/2017 Built 190751
delivered - 3/5/2017
kparker is offline   Reply With Quote
Old 02-23-2017, 10:40 PM   #12
nate.the.great
Drives: 2017 Camaro 1SS 1LE
I drove mine in snow with Pirelli PZero Nero all seasons while in Snow/Ice mode. There's no issue with traction, the problem is clearance. Driving in fresh snow is fine, the car can sort it all out. However, once the snow freezes overnight, there are frozen grooves/ruts in smaller roads that aren't plowed as often. I'm pretty we don't have enough clearance for those frozen ruts. On that day, my wife dropped me off at the bus station in her Honda Odyssey. Even the van scraped on some of that frozen snow.
nate.the.great is offline   Reply With Quote
Old 02-24-2017, 01:50 AM   #13
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
If you have a car you can use for the really bad snowfall, you'll be fine. If you have to attempt to drive on more than 6 inches of un-plowed you will be the one plowing the snow for everyone else.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 02-24-2017, 07:29 AM   #14
Tomiboy
Drives: 2017 Hyper Blue 1LE
Originally Posted by Sleeks View Post
Those wheels look nice!
Tomiboy is offline   Reply With Quote
