Old 02-22-2017, 06:46 PM   #1
Track_OK
Track_OK's Avatar
Drives: 2016 1SS M6 Summit White
FI daily?
So I have an opportunity to go FI with a Procharger setup and one of the things holding me back is whether or not I can daily it at an average of 15k-20k miles a year. I'm just wondering if its a waiting game until something pops? Or should I be expecting it to last as long as a stock engine?
Anyone with some/any experience in this please chime in.
Thank you!
Track_OK is offline   Reply With Quote
Old 02-22-2017, 06:49 PM   #2
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
Dit it on my 4thGen Vortec LT4 ...had over 100K and still running strong, I don't know if you still need to change plugs out at 10-12K miles but I did....
Yellow6thGen is offline   Reply With Quote
Old 02-23-2017, 10:34 AM   #3
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Thank you!
Just service it like the instruction say and you'll be good to go. I know several guys who DD Monday - Friday and race on the weekends that have several 1000's miles on their set up.
Perdieu is offline   Reply With Quote
Old 02-23-2017, 10:49 AM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Thank you!
I'm going to say it is all on how you drive the car. If the engine has a forced induction system installed it will be able to put a lot more stress on your parts. I still expect that you could drive the car 100,000 miles with normal maintenance. It is the same whether or not you have forced induction, if you drive the car hard it will have more problems in the long run than it will if you are conservative with the throttle.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
