![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
ATF for TR6060?
In the process of getting all my fluids changed and moved over to synthetics. Im an Amsoil nut swinger and it has always served me well in the past. Im seeing that the TR6060 recommends ATF? Am I seeing things or is this correct..
Plan on switching the motor oil/ trans fluid and diff/ELSD fluid(GM fluid) and swaping over to some motul 600 for the brakes. Getting ready for it to start heating up and hitting the track! |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
It was the same way for the 5th gen as well....It's what it calls for.
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I know my last TR-6060, albeit years back, was not synthetic friendly...not sure if that has changed. May even want to call Tremec...
Planning stages...
Drives: 1995 Z28,2014 Ford Focus ST Join Date: Dec 2007
The T-56 in my '95 Camaro, which is a distant ancestor of the TR-6060 I think, specifies ATF as well. The Redline D4 was a big improvement over the GM or Mobil 1, so I'm sure the Amsoil will be as good or better than the RL was.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
マスタング = 遅い
I used to use the GM Synchromesh in my T-56's with great results...I wonder if that is still around and usable in a TR-6060...I need to look.
#7 | |
#8 |
![]() Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
Same here, my T-56 in my '01 SS calls for ATF. Theres a tag right on the side of the trans. I know Ford Rangers of long ago required ATF in their manuals as well. Not an uncommon thing, ATF has a high shear strength and flows better at colder temps than gear oil.
#9 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
This transmission is the least of my concerns. I believe its the most bullet proof part of the whole car. The HP supplement doesn't even recommend flushing it after a track day or anything. I'm not touching the fluid until the it's recommended in the manual. I probably won't touch the trans fluid my entire ownership of the car!
#10 | |
