Old 02-21-2017, 08:32 PM   #1
aw113sgte
Drives: none
Driving feel 1le vs SS with magride
Obviously the 1LE performs far better. I am wondering how much different the feel is compared to the SS?
Is the steering more communicative? Does the car feel lighter/more flickable? Brakes feel different?
The eLSD is a big question mark but I assume it only makes a difference in feel on acceleration.
aw113sgte is offline   Reply With Quote
Old 02-21-2017, 08:54 PM   #2
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Mag ride. Totally awesome..
Better steering ..
Check . More Flickable..check
Better brakes .check. elsd works for cornering and acceleration. Check.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 02-21-2017, 10:16 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
For me personally, it brought the SS from "this is nice" to the 1LE "I have to buy this". The steering feel is better, the chassis composure is better, and the eLSD + PTM is transformative. The SS in Track mode is akin to the 1LE in Touring mode. If you're hardcore enough where that sounds like a good idea to you, then the 1LE is for you.
The package makes the car feel significantly lighter than the scales show. I'm coming from prepped track cars that weigh 2350 (MINI), 2218 lbs (Miata), and 1919 lbs (Exige S), so something this heavy feeling this good seems like a violation of physics, but it's how far technology has progressed in a few years. On top of that, the 1LE actually works on the street, something my prior track cars just can't admit to with a straight face.
Old 02-22-2017, 06:15 AM   #4
Tomiboy
Drives: 2017 Hyper Blue 1LE
This!
Tomiboy is offline   Reply With Quote
Old 02-22-2017, 07:58 AM   #5
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Everything everyone said above is correct. The SS is a very solid performer, but the 1LE takes it to a whole new level! I had a 2SS as a loaner and you could feel the difference big time! Honestly the difference between the SS and the Mustang GT PP feels about the same as the difference between the SS and the 1LE.
This past saturday I got some instruction from SCCA Champ Darren Seltzer and I think his reactions in this video say it all. I think it's fair to say that was a very low speed technical course that was much more suited for small nimble cars. Even so Darren set the fastest times of the day in my car. The other cars consisted of stock and modified MX-5's, S2000's, MR-2, and a 500hp AWD eagle talon with wide tires!
BTW ever get that feeling where you can't stand the sound of your own voice on video? HAHA That's me right now! SHUT UP AND LET THE MAN TALK ABOUT THE CAR!!!
Originally Posted by Darren Seltzer
WOW THIS CAR IS PHENOMENAL! Does this have that fancy suspension that the Corvette has?
Originally Posted by mjk3888
It does. It has the Mag Ride on it.
I can tell, because its in a turn and its just like...
it's working!
it's working!
it's working!
and I'm like ah this shouldn't be working... BUT IT'S WORKING!!!
it's doing GREAT!!!
Old 02-22-2017, 08:07 AM   #6
Casalino
Casalino's Avatar
Drives: 17' 1LE BLK
Just hit a nice sized bump on an on ramp doing about 55 mid-turn. Then you'll really be impressed. The car hits bumps with composure. Doesn't seem to upset the balance whatsoever. I think it has to do with the weight and the dampers. But the weight helps in this sense. All the bump did while i was going round the bend was shift the car over maybe a foot/6 inches. But it dug deep and kept going! Mind you i was on an on ramp that was rated somewhere around 15-20mph. Doing about 50-55 mid-turn and coming out about 60-65. Never upsetting the balance, that was key. It simply hit the bump, shifted over, planted itself and kept diggin. Awesome car
Casalino is offline   Reply With Quote
Old 02-22-2017, 08:33 AM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I can't get over the traction of this car...
Between the eLSD, the wide sticky tires, the suspension, the traction is very impressive. Things that would have upset my previous (full suspension) Coyote Mustang and would have made it lose traction, just do not do a thing to this car...
Old 02-22-2017, 08:23 PM   #8
TJay74
^^^^ This...
Was out on a ride with the wife tonight, turned the T/C off and from a 1st gear I rolled into and NLS into 2nd, the tires barely even moved and the car stayed planted the entire time.
Old 02-22-2017, 08:33 PM   #9
MatthewAMEL
MatthewAMEL's Avatar
:WHS: It's a big, fat Miata.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 02-22-2017, 08:59 PM   #10
MAGAUSA
MAGAUSA's Avatar
FWIW I was sold on a 2SS, thought I needed all the extras and then sat in and then drove a 1LE and that was all it took. Looking back I would not buy a loaded 2SS or any Camaro over this car. It's truly amazing. I've had much more expensive supposedly engineered cars and this out performs them in every way. Just get one.
MAGAUSA is offline   Reply With Quote
Old 02-22-2017, 10:20 PM   #11
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
I had a 2013 1LE and fell in love with that cars handling. It was amazing. Had a 2015 Mustang GT PP car. Installed the Ford racing handling package. Square 10.5" setup with 285 tires. I could not get that car to feels as composed as the stock 2013 1LE.
So I end up with a 2016 2SS with mag ride. Car is magnificent in the handling department compared to the modded
suspension GTPP.
So I've installed the Pfadt/AFE springs and 1LE sway bars. Added 20x10 and 20x11 1LE replicas. I have Nitto 555 G2 tires in the 1LE size. The car is even better now. I would be willing to bet that you put oem 1LE tires on my car, you would have a hard time differentiating the two cars grip and composure. I do give up some braking without the better brakes I'm missing, but the factory SS brakes are no slouch either.
In my opinion I've built damn close to an A8 version of the 1LE. Opinions may vary, but that's mine.
1LE Red Dragon is offline   Reply With Quote
Old 02-23-2017, 07:55 AM   #12
TJay74
suspension GTPP.
I still think while you are close, the Magnetic ride programming and the eLsd also add into the handling and give the edge to the 1LE over a SS that has added the parts to the car.
Old 02-23-2017, 10:01 AM   #13
WhyUMad1LE
Drives: 17 SS 1LE
Slightly stiffer/more planted but not a night and day difference on the street. You don't need more than the non MRC SS suspension for a street car imo
Old 02-23-2017, 10:38 AM   #14
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
So you guys are telling me that the 1LE vs a 2SS WITH MRC is a whole lot different.... I agree it will be more planted and tighter...
I think most are comparing MRC vs non-MRC cars- a hole different ball game. After driving a car with MRC I immediately felt the difference.....
