View Poll Results: Do you have a K6 Relay in the front fuse box? | |||
Yes | 7 | 63.64% | |
No | 4 | 36.36% | |
Voters: 11. You may not vote on this poll |
Thread Tools |
02-17-2017, 11:15 AM | #1 |
Do you have a relay in K6 front fuse box?
So have ran into something that seems odd about the front fuse box on my 2SS. It seems I have a relay in the K6 position that some people do not. That wouldn't be surprising except the fuse is labeled as "Coolant Pump" in the owner's manual (pg. 280, 282).
Even more interesting is I have seen several member pictures of their fuse box which are SS cars that do not have this relay. The MY doesn't seem to matter since it's listed on the 2016 and 2017 owner's manual. My guess is it could be because mine is an Auto, but would like to see what everyone else has. If you have the relay, just post your car details (A8/M6, MRC, etc...) I'm including a shot from the owner's manual and my fuse box:
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-17-2017, 03:09 PM | #2 |
Drives: Hyperblue 2016 1SS Join Date: Jul 2016
A8 NPP and yes I have the relay.
Edit: Build date 6/2016 Last edited by Deviousin10tions; 02-17-2017 at 05:24 PM. Reason: I'm dumb |
02-17-2017, 03:19 PM | #3 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
2016 A8 NPP, MRC, no sunroof, 4 pot brakes and I do not have a relay there. You have my interest. 3/16 build date
EDIT: F54 says "coolant Pump" in the manual as well. I see you have a fuse there as well. I do not have the 15 amp fuse there. Clearly my car does not have whichever coolant pump this is for. EDIT 2: I just saw in another thread someone say "That's probably for the ZL1's intercooler coolant pump" so maybe they just put that in there for 2017 and late 2016 builds as it is cheaper to run the same fuse block down the line. It makes sense because the ZL1 does have an air to water intercooler I believe which does require a pump. Last edited by Eric SS; 02-17-2017 at 03:40 PM. |
02-17-2017, 04:47 PM | #4 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
2017 2SS convertible, A8, NPP, MRC with K6.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
02-18-2017, 11:23 AM | #5 |
So Eric's response seems to rule out the auto having anything to do with it. Which is even crazier seeing now we have 16 and 17 cars with it. With both SS trims having the same cooling system, what could this thing be for?
Sent from my SAMSUNG-SM-G920A using Tapatalk
02-18-2017, 01:13 PM | #6 |
Try removing it and starting the car. See if you get an error or warning. If it is cooling-related you could drive the car for a bit and watch temps. You can always pull over and put the relay in again.
02-18-2017, 06:25 PM | #7 |
Seems a bit risky for simple curiosity. I'm tempted to take a trip to the service dept and see what they pull up about the relay in the system.
02-18-2017, 08:48 PM | #8 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Have someone post the 8-digit number off the top of their relays and google them. GM relays are pretty specific part numbers per system, so it should give you enough information to figure out what it is used for.
02-19-2017, 10:41 AM | #9 |
Looking at the videos in the review section of Mishimoto, I see no mention of an electric pump for the stock SS, although it is interesting to see that both the manual and automatic cars include both transmission and differential cooling circuits, as well as oil cooling.
Videos 4 and 5 detail the cooling system for stock SS: https://engineering.mishimoto.com/ca...ehicle-review/ I believe this relay and fuse are most likely for the ZL-1 intercooler pump as someone speculated above. See this schematic (in post #9) for the gen5: http://www.camaro5.com/forums/showthread.php?t=255716 |
02-19-2017, 04:45 PM | #10 | ||
02-19-2017, 07:29 PM | #11 |
Drives: 2016 2SS Join Date: Mar 2016
the part number is the number for the relay, nothing to do with what it is for. also, look at the relays, they are the same pn
02-19-2017, 07:30 PM | #12 |
02-19-2017, 07:33 PM | #13 |
Drives: None Join Date: Nov 2016
2017 1LE and I have a relay.
-Brian
Hyper Blue 1SS / 1LE |
02-19-2017, 10:02 PM | #14 |
Drives: 2017 Camaro 2LT 50th Anniversary Join Date: Sep 2016
Maybe it has something to do with the cooling package? Do the people that have the relay bought their car with the cooling package and the people that don't have the relay don't have the package? Seems logical since the relay is for the coolant pump.
