![]() Drives: 2016 2ss Join Date: Jun 2016
Borla exhaust sounds...not muscley
I think I'm just stuck on an idea, but I have the borla s type on my ss and it sounds almost ricey to me compared to the older ls1 engines. Do you think that's the exhaust or the nature of the lt1?
https://youtu.be/X6H1QdcPphg
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
And.......if I wanted to try flowmasters, do you think anyone would buy the used borlas??
![]() Drives: Summit white 1le ss Join Date: Feb 2017
Have you thought about the borla atak
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
It won't sound deeper just louder like Corsa's. If you want a deep muscle sound Flowmaster's sounds beastly.
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
I think its partly the Cats. I have the MBRP which is basically straight pipe and it sounds like a muscle car but its still not rumbly like I'd want it. Headers may be your best bet.
To get the sound you are looking for, you will likely be encounter with Drone at cruising speed. I had SW, and switched to Borla for that very reason. Did you install the Borla X-pipe catback system or just the axle back?
#7 |
![]() Drives: 2017 M6 NFG Join Date: Jul 2016
just an axel-back will only get you a certain sound, adding catback,headers, and then each combo can give you different sounds and sound is subjective. In the end, an LS1 won't sound like a LT1 and vice versa no matter which exhaust comb you use on either. Listening to certain exhaust setups on other peoples LT1's in person is going to help you most.
#8 |
![]() Drives: Mosaic Black on Black. 2017 M6 2SS. Join Date: Sep 2016
Stainless Works have the deepest tone i think
#9 |
![]() Drives: 16 2SS Join Date: Jun 2016
#10 |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Try a muffler delete. It's free to try once you pull the bolas off!
#11 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
If you want an old school muscle car sound (dated IMO) then you should look for an H pipe and a flowmaster setup. You will lose a bit of power though, but probably not enough to notice. |
#12 | |
![]() Drives: 2016 SS Garnet Red A8 Join Date: Jan 2016
muffler and secondary cat delete ! |
#13 | |
rev in a parking garage haha |
#14 |
I can tell you LTs/cats make the sound high pitched. I have not heard any LT1 with a deep rumble. High compression I think.
A truck like H-pipe as mentioned may help, but a couple less HP.
