Old 02-14-2017, 08:13 AM   #1
tecboy
tecboy's Avatar
Bose ANC Plug Type?
Does anyone know the specs of the plug that the Bose ANC microphones are connected to? I would rather make a inline harness rather than cut the mic leads..
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 02-15-2017, 11:14 PM   #2
JaxChris
I don't think the ANC mics connect directly to the Bose amp. The Bose system in the 6th gen Camaro doesn't use the Bose proprietary ANC system (Bose ASM w/ EHC). Instead, it uses the same system GM licenses for most of their volume vehicles (which I believe is from Pioneer). That system feeds to the receiver, which calculates a solution tone and passes it to the amp via a separate mono channel wire to the amp. That mono channel is then blended with the rear deck speaker signal by the Bose amp.
Old 02-16-2017, 07:23 AM   #3
tecboy
tecboy's Avatar
there is a plug in the bose amp that the wiring diagram shows 2 wires for 2 mics...i decided to go a different route and just unplug them in the door vs cutting wires at the amp....everyone who has had the noise when adding subs....said cutting those mic wires fixed the problem
Old 02-20-2017, 07:29 AM   #4
JoeAyalaM
Drives: Audi S6 V8TT, Volvos XC60 & S60R
I did that, just unpluged them, and it worked just fine.
JoeAyalaM is offline   Reply With Quote
Old 02-20-2017, 06:03 PM   #5
Gilley
Gilley's Avatar
Drives: 16 Red Hot 2SS
I have read that there is one clip for the door panel that is a single use clip and must be replaced with new each time. Did you have to replace any clips when you removed the panel to disconnect the ANC mics? Or did you just reuse the clips? If you bought new clips do you have the part number or description?
'16 Red Hot 2SS A8 sunroof
Gilley is offline   Reply With Quote
