Old 02-11-2017, 07:38 PM   #1
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
How to Remove Intake Manifold
I'm in the process of removing the intake manifold and tb from my 6.2 to have sent out to be ported. Can anyone please let me know how to do this and any links to possible parts that would need to be replaced in the removal process. I have read through the forums and searched google but cannot find any videos or descriptions of the process. I did see that amazon might carry replacement plastic parts but I don't know what parts. Any help would be greatly appreciated.
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 02-11-2017, 08:26 PM   #2
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
I have taken my intake manifold off and on 4-5 times now. It is not that hard at all.
Couple things: With the OEM I.M. if you break something you need a whole new manifold or JB weld. The ports and connectors on the OEM look screwed on but they are not. They are all fused on. Also I would not recommend exposing your heads for that long. (aka sending it off) without a replacement I.M., as a place holder, or some serious engine cover. The heads funnel right onto the valve and just closing your hood opens up the possibility of animals or dirt getting in and causing a valve to not seal or worse stick. I would recommend going to the hardware store and buying some sand paper (320,240,180,100,60 grits) and doing it yourself. Start rough and end smooth. (gigidy) The I.M. is literally two sensors, 4 bolts for the throttle body, and 10 bolts for the I.M. and off it comes all with a 10mm socket. The hardest part is getting the brake booster line to release on the rear of the I.M.. Its in a hard to reach spot and requires you to get a flat head screw driver in there to hold the slip collar down while pulling back on the tube. Take off all the bolts then slide the I.M. forward until you can reach the booster line. DO NOT PULL ON IT TO HARD!
EZPZ: total time to take off 1-2 hours if you go slow.
Whitemaro6 is offline   Reply With Quote
Old 02-11-2017, 08:28 PM   #3
PRAY
PRAY's Avatar
Drives: 2016 2SS
I will just assume you are sending your IM/TB to me for porting so I will help you out.
The swap is really easy actually. I can do it in about 15 minutes now.
Pop your Camaro covers
Pop your wiring harness from the gray cover before you un bolt it
Remove the gray cover
Leave the black cover under the gray cover for now (remove it before you ship)
Leave your brake booster hose connected at the rear of the manifold and disconnect it under the A/C line (remove it after you have the IM out)
You can leave the TB connected at first, just get the connector off
Leave the air box in place and just remove the elbow
Disconnect the EVAP solenoid
Loosen all of the IM bolts and hold them up with the rubber bands
Take the TB up and to the right and the IM will slide right out
Separate the IM/TB wrap up tight and ship
That's about it.
Old 02-11-2017, 08:32 PM   #4
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I'm assuming that this IM takes a good torque wrench and specific torque pattern when re-installing. If it does, that would be great info to know.
Old 02-11-2017, 08:36 PM   #5
Whitemaro6
Whitemaro6's Avatar
75 pounds over several passes. Here's the info. Different looking mani same procedure. Honestly the amount of torque is so low you can feel it by hand when the intake contacts the heads. I do not even use my torque wrench anymore I just feel it. (do not hate)
Old 02-11-2017, 09:34 PM   #6
Brianw36
SNSTRSS
Brianw36's Avatar
Thanks for all the great info. Yes Pray I will be sending it to you to have done. I plan on taking it off next weekend. Do I need to order any new gaskets or bolts to reinstall? Thanks Whitemaro6 for the torque sequence.
Old 02-11-2017, 09:42 PM   #7
ULTRAZLS1
ULTRAZLS1's Avatar
75 inch pounds sounds about right. They didn't seem very tight at all.
Warning to all who may not know the difference. It's not 75 ft lbs. that would break the bolts and or crack the manifold. It's more like 6-7 ft lbs.
I'd suggest a 1/4 inch drive inch lb specific torque wrench if one wants to do it just right.
I'd like to know the torque specs for the stock manifold it's probably similar to the msd above. Tighten in a criss cross pattern. Then re torque them all one more time to be safe.
Bolts will be fine. Gaskets are rubber and should be ok especially on a newer car.
It's one of the easiest intakes to remove I've ever done.
Old 02-11-2017, 09:56 PM   #8
Whitemaro6
Whitemaro6's Avatar
Nope no new bolts or gaskets just hold on to the ones that come off the OEM and put them back on when done
Old 02-11-2017, 10:01 PM   #9
jdasnt3
jdasnt3's Avatar
Thank you all! Great topic and info.
Old 02-11-2017, 10:22 PM   #10
Whitemaro6
Whitemaro6's Avatar
Boom here you go gents
Old 02-11-2017, 11:15 PM   #11
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Agreed, great info!
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 02-12-2017, 07:46 AM   #12
wnta1ss
Drives: 2017 Camaro 1SS
I think this part is important enough to be large
75 inch pounds max NOT foot pounds!
This is a piece of plastic
Old 02-12-2017, 08:02 AM   #13
Immoralus
Immoralus's Avatar
Drives: 2017 Camaro 1SS A8
This is awesome! I too was wondering.
Immoralus is offline   Reply With Quote
Old 02-12-2017, 08:03 AM   #14
PRAY
PRAY's Avatar
Drives: 2016 2SS
Well that is good news. I am glad you chose to go with us. Thanks.
