Old 02-10-2017, 02:01 PM   #1
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
New JL Audio Subs for 16/17 Coupe
Just received this from JL Audio
It doesn't fit the Convertibles only Coupe
http://www.jlaudio.com/sb-gm-cam6g-1...ealthbox-94633
SB-GM-CAM6G/12W6v3
Chevrolet’s 6th generation Camaro delivers a powerful shot of adrenalin and all-American, classic muscle car looks. Unfortunately, its stock sound system lacks real low-frequency punch and definitely needs some help in the bass department.
This Stealthbox® is designed to produce powerful amounts of ultra-deep bass with minimal loss of useful cargo space. Its 100% fiberglass sealed enclosure houses a highly potent 12W6v3 JL Audio 12-inch subwoofer and neatly tucks into the driver side, rear corner of the trunk. Rear-seat pass-through functionality remains unaffected, and full access to the under floor battery compartment is retained. Also available in 12TW3 driver model.
The Hard Data: Contains one 12W6v3-D4 in a sealed enclosure. 600 watt power handling. Wired for a 2 ohm load. Installs in the driver side rear corner of the trunk. Minimal loss of trunk space. Black steel mesh woofer grille included. Installation requires permanent modification to the driver’s side trunk liner. Will not fit convertible models!
Stealthbox® Color & Ordering Information
MODEL SKU# PRICE Year(s) OEM Color Match Grade Woofer(s)
SB-GM-CAM6G/12W6v3 94632 899.99 16-Up All (trunk liner) Contrasts One 12W6v3-D4
Yellow6thGen is offline   Reply With Quote
Old 02-10-2017, 02:15 PM   #2
CyberGuyPR
CyberGuyPR's Avatar
Drives: '16 vert 2LT RS NPP
Covered here: http://www.camaro6.com/forums/showth...=481245&page=2
CyberGuyPR is offline   Reply With Quote
Old 02-10-2017, 02:16 PM   #3
yeti16
yeti16's Avatar
Very cool! On my list!
yeti16 is offline   Reply With Quote
Old 02-10-2017, 02:42 PM   #4
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
Unless it comes with a plug and play harness to connect to the Bose system without too much effort, I'll pass. For $765 I'd go through with the hassle of building a full on sub setup...
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 02-10-2017, 02:55 PM   #5
RSKUSTOMZ
RSKUSTOMZ
RSKUSTOMZ's Avatar
Drives: 2010 Camaro T-top RS
And bang for the buck, these Stealthboxes sound amazing. I do ALOT of the JL Audio enclosures and have YET to be disappointed with any of these.
RSKUSTOMZ is offline   Reply With Quote
Old 02-10-2017, 03:29 PM   #6
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
Is this a non-powered unit, meaning I need to get an amp for it?
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 02-10-2017, 03:39 PM   #7
7stringtheory
Drives: 2017 Camaro 1SS 1LE
Yes it is a non-powered unit that requires an amp. You also have to cut into the side of your trunk liner to install it. So if you were to remove it there would be a hole in the side of your trunk.
7stringtheory is offline   Reply With Quote
Old 02-10-2017, 03:54 PM   #8
ctrlz
Nice to see products like this emerging. Price, for me, is steep for a non-amplified unit
I would like to see amplifier solutions which interface to the stock systems without necessitating the loss of any functionality, including ANC.
Old 02-10-2017, 04:19 PM   #9
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Need a convertible version!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 02-10-2017, 09:20 PM   #10
Yellow6thGen
-Geoff
Ditto I'm till waiting.....
Old 02-10-2017, 11:12 PM   #11
VCSRT
Drives: Jeep
I killed 2 W3 subs, at rated RMS. I wouldn't touch them again, I'm pretty sure Sonic Electronix would prefer I did too.
VCSRT is offline   Reply With Quote
Old 02-10-2017, 11:22 PM   #12
SociallyAwk
SociallyAwk's Avatar
Drives: '17 SS 1LE
Excuse my lack of knowledge, but aren't ported boxes better for quality/loudness? I know a stealthbox is for saving space vs. a big box, but if we ignore space being an issue- isn't it more worthwhile to go ported?
SociallyAwk is offline   Reply With Quote
Old 02-11-2017, 05:18 AM   #13
2006Moy
Drives: 2016 SS Convertible Hyper Blue
Ported lets the cones move freely and can cool more. They reproduce a more "boomy bass". Sealed can sound tighter on bass more SQL. If done correctly though a ported box wont boom, they can be just as crisp. As far as worth while its totally an individual choice for the application.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards
Mishimoto catch can
Black hash marks
Curb alert
Vitesse controller
Jl audio HD 900/5 amp
c5 650 components
c2 650x coaxials rear fill
2 x 8" W3v3 subwoofers custom ported box
Fix 82 module
BF TPNS
BF Wet Diamond
BF Crystal Seal
Hydr02
303 Aerospace top protectant
2006Moy is offline   Reply With Quote
Old 02-11-2017, 10:36 AM   #14
ctrlz
You basically just need to follow the guidelines for enclosure design and amplifier power. An acoustic suspension (sealed) enclosure will sound great if executed properly.
