02-10-2017, 10:27 AM | #1 |
Drives: 2018 camaro zl1 , 2007 porsche GT3, Join Date: Dec 2016
Track alignment done...definitely check yours
I just had my track alignment done. The right rear toe setting from the factory was way out.
02-10-2017, 10:54 AM | #2 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Thanks for posting!
Any idea what the correct stock OEM alignment specs are? -1.2 camber front and rear? |
02-10-2017, 11:23 AM | #3 |
02-10-2017, 11:30 AM | #4 |
02-10-2017, 01:53 PM | #5 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
I wonder why the caster is not displayed. Is it maxed out at -2.0 camber or you just wanted to stick to recommended user manual numbers?
02-10-2017, 02:11 PM | #6 |
I had it done at a highly respected race shop and i let them set it up. Unfortunately i didn't track it before so i wont know how much faster it is.
02-10-2017, 03:48 PM | #7 |
Did they replace your strut bolts?
02-10-2017, 03:53 PM | #8 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
They are only "one time use" if you over torque them...
BMR has said this multiple times as well. |
02-10-2017, 04:18 PM | #9 |
Guess I misunderstood, thanks for clarifying SS 1LE
02-10-2017, 08:19 PM | #10 |
Drives: 2017 SS 1LE Join Date: Oct 2016
You can and should change the Hunter alignment software to degrees for the toe setting measurement and adjustment. It can easily changed back if mm (old school) is needed.
In reference to your measurement, when was the rack calibrated last? It should be done at least once per year. And make sure the wheel sensors didn't slip during the rolling compensation to ensure an accurate read-out. Here are the manufacturer center alignment specs for the 1LE: V8 1LE Street: Front camber: -1.00 deg Front total toe: +0.20 deg Rear camber: -1.00 deg Rear total toe: +0.20 deg V8 1LE Track: Front camber: -2.00 deg Front total toe: +0.10 deg Rear camber: -1.50 deg Rear total toe: +0.10 deg
2017 SS 1LE Hyper Blue - PDR - TSSHKX
2017 SS 1LE Hyper Blue - PDR - VBHF63 Last edited by NBR IPD; 02-10-2017 at 10:04 PM. |
02-10-2017, 09:09 PM | #11 | |
03-07-2017, 06:04 PM | #12 |
Drives: 2017 Camaro SS 1LE Join Date: Feb 2017
After driving my 1LE for 350 miles, I decided to do a quick check on the toe. No surprise, both the front and right rear wheels were out. Took it to Mr. Goodwrench, and since it is under 5000 miles, the alignment was free. They confirmed that not only the toe was out, but also the camber. Now the car drives wonderful.
03-08-2017, 07:27 AM | #13 | |
マスタング = 遅い
Did you have to remind them to use SS 1LE specs? I would be worried about a careless tech not using the right specs. Pretty sure these are the SS 1LE specs: Front camber: -1.00 deg Front total toe: +0.20 deg Rear camber: -1.00 deg Rear total toe: +0.20 deg |
03-08-2017, 08:02 AM | #14 |
Drives: 2017 SS 1LE Join Date: Mar 2016
So I was planning on having the track alignment done before the big 2 day Auto X event in Charlotte next month (also my 1st event!!!) would be ok to leave it with the track alignment after or should I pay to have it put back to street spec? Or is the track alignment pointless for Auto X?
IG: @NC_M1SS1LE
